The problem with most of less expensive (and many expensive) large memory depth scopes is that they really suck when large memory depth is used. UI becomes really sluggish, waveform capture rate drops dramatically, and so on. Specs like capture rate are usually given only in best case scenario, when combined with memory depth or math functions, often there appears a problem. Keysight scopes on other hand almost always work with max memory depth with all of that high capture rate and responsiveness. Need to be aware of that and do your own research when making a choice.
