I've recently acquired a Lecroy WR6030, which failed to start the Waverunner software. Did a clean install (W2000 -> WXP) and the unit since then worked flawless
![Scared :scared:](https://www.eevblog.com/forum/Smileys/default/scared.gif)
. Big thumb up for all the work already done on the forum, including the working touchscreen-driver
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
After a bit of playing around i found out this (non-a) 6030 supports 2x 5GS/s in interleaved mode, but the datasheet and the front panel suggest only 4x 2.5GS/s is supported. Only the 6030A should support this conform the datasheet. Did Lecroy upgrade these units by just updating the firmware? The unit is probably 'uphacked' by the previous owner as all the options are available including non-ordeable USB2 and ENET. The status menu does mention the unit is a 'WR6030'. Firmware is 8.1.2.0, latest available. Did they really gave the doubled sample-speed for free or am i missing something?
![Upgrading Mainboard in Lecroy DDA-3000 (aka WavePro 7300a?)](https://www.eevblog.com/forum/index.php?action=dlattach;topic=67407.0;attach=897034;image)
The oscilloscope feels a bit slow and the fans sound like they need replacement, so i will upgrade this unit to W7Pro, S775, core2duo E6600 + SSD if i can find the right Motherboard. The combination of right chipset, available PCI-slots, AGP slot and native SATA is quite hard to find.
The unit now only has some cosmetic 'problem', the previous owner lost or broken the original front-panel knobs (
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
) and therefore the knobs are replaced by some ugly black-red universal knobs. And not one, but all of them. Does anyone know if Lecroy is willing to sell replacements or if the original knobs (or some universal white knobs) are commercially available? I've tried Farnell, Digikey and AliExpress but the combination of grey/white + D-shaft does not gave a lot of options.
