dont forget to search around eevblog for Lecroy SW/OS upgrade, installing from fresh disk, Win7, and err...
Sure thing, I'm moderator at 2 other forums so i know were the search button is lurking
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
As with a new motherboard you also have to install the software i try my luck in this topic. Maybe someone reading in on this topic knows the solution.
So after an evening tinkering we got the unit online with the original hardware. Intel board had 3 Blown cap's. Repaired that.
Had struggles with Win2000, got SP 4 installed,
Installed all original Intel drivers that are on the Intel website for this motherboard. Including the Intel Extreme Graphic Driver for 845 chipset V6.14.10.3762
This is were the troubles starts. As soon as the driver is installed and the machine does it's reboot. The front LCD Ghosts away at the point of windows starting it's welcome screen.
And stays dark. When booting with an external monitor to the VGA port and without the AGP card inserted we are able to get an image and even start the Xstream Software and run the scope.
So we guess or the Intel driver we have is faulty, or the settings are not ok for the front LCD.
When we de-install the Intel driver we are able to run the front LCD in windows in 640x480 at 16 colors. But of coarse this is not able to run the software of 16 colors.
So all in all we revived a LeCroy from the death. All because the great info in this topic, so we were quite positive that we were able to revive it.
But missing that 1 piece of driver / setting to get it up and running with the build in screen again.
![Broken! :-BROKE](https://www.eevblog.com/forum/Smileys/default/smiliey_scope_broke.gif)
We will upgrade the hardware in the future. But we bought the scope as we need to do measurements on 3Ghz in the next couple of weeks to get a Hardware design up and running. If that product is out the door. We will possible go for a Win7 i3 / i5 setup with Ipad front screen.
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
To our surprise the machine was loaded with options. DFP2 ENET ET I2C JTA2 PMA2 SDM SPI USB2 XDEV XMAP XMATH
![WTF? :wtf:](https://www.eevblog.com/forum/Smileys/default/wtf2.gif)
Hardware option -M so small memory package..
For the feet. The printing was very successful
![Azn ^-^](https://www.eevblog.com/forum/Smileys/default/azn.gif)
It got really good strength due too the design being "Solid" with that Honeycomb, which makes it much more strength then the open structure of the original feet.
Printing 4 of them took about 5 hours with our Flashforge Finder printer and takes about 20 meters of PLA material.
You need to add some support material underneath with the slicing program of the 3D printer. But anyone that is used to run a 3D printer knows how. Also the best results are gone with a Raft underneath the object.
Here some photos and i hope that i can include the zip file as new user.
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
