My experiences:
a) Bought U2 Basic.
b) Opened it up, wires pin 4 to 7 on the SPI flash
c) Reflashed with the "Basic" hex using the modified fx2lafw_eeprom_loader_u2b.exe - replugged, works (with current latest DSView 1.0.1) recognized as Basic model that does 400Mhz (appears to work fine, but obviously no real buffer memory)
d) Replaced SDRam with 48LC16M16A2-75 (hot air and microscope. I think I did it ok, we shall see..)
e) Booted again (still as 'Basic'), still works (as it's ignoring the SDRam)
f) Flashed this "Basic" version with
https://raw.githubusercontent.com/podonoghue/LogicAnalyser/master/Software/fx2lafw_eeprom_loader/bin/DsLogicPro hex file using the 'unmodified' fx2lafw_eeprom_loader.exe
g) DSView 1.0.1 recognizs it as DSLogic Plus, but hangs ("waiting for trigger") when capture starts
h) DSView 0.9.9 does work: Streaming mode: works but oddly I see periodic one-sample zero glitches (e.g. every 16 samples are zero) on all channels. Self-test doesn't even work right. Ack. Stuff is all half-broken, lots of bad samples and stuff. Dammit.
i) Put board back under microscope and redid the SDRam soldering, it wasn't a great job the first time
j) Plug it back in and... lots of it works! (on V0.9.9) I fed in a 25mhz clock to the first four channels and sampled it at 400mhz (buffered mode) and it's fine!
e.g.
j1) Buffered mode, 4 channel, 400mhz sampling, with 167.77ms buffer (max available; not using RLE) == 400M*0.5*0.167 = 32MBytes = 256MBit. The data (25mhz clock on all channels) looks great. Adjustable input voltage threshold is working too.
j2) NOTE: RLE modes do _not_ seem to work reliably for me at >100Mhz speeds:
8 CH @ 100mhz, 200ms RLE sampling works ok, but stepping same thing to 200mhz gets me garbled results, channels shifted around, general half-crap.
However, if I do the same 8CH/200mhz buffered without RLE, the data (superficially) looks good.
So.. almost fully working...
The RLE crapping out at 200Mhz and up may imply sporadic SDRam errors (that are perhaps returning a few wrong samples not visible to the eye in non-RLE mode; obvs errors in RLE would cause large ripple effects on the data, like what I'm seeing)
This may well be memory access time problems (I am using a -75 chip).
I may swap the SDRam for a faster one, or just not use RLE modes on this and treat it with a bit of suspicion over 100mhz.
V1.0.1. note:
You can (kinda) use this with 1.0.1 software too - you just have to use the bitstreams from 0.9.9 (as pointed out on here);
in the "DSView/res" folder you can replace the "DSLogicPlus.bin" xilinx bitstream file with the one from 0.9.9
(Note that the firmware is only loaded if the device has not been programmed since it was plugged in, so you can (for example) run v0.9.9, do a capture, then quit and run V1.0.1)
I assume the 1.0.1 bitstream is superior, but it hangs on start on a hacked unit. Pehaps my RLE errors are actually something they fixed in the new bitstream.. ? More likely they are that my SDRam is too slow. We shall see...
