Need help on the following issue:
It started with the MSO-X 3024A Agilent infiniivision getting into a never ending loop during power-ON. It just continued the sequence of lighting the LED's in a sequence during start up and continued forever. The Agilent screen was up and stood still. But sometimes it comes on normally.
So after reading posts on this forum, which matched my above problem, I updated the firmware. My previous firmware was version 01.10.20111031600. and had installed licences of MSO, BW20, WAVEGEN.
After 'successfully' installing the firmware as per the instructions, in the 'About this Oscilloscope' tab it shows the below info:
Model number: Unset
Serial no 7290
Bandwidth: 200MHz
Module Installed: None
Firmware version: 02.50.2019022736
Installed Licences: MSO, SGM,BW20,EDK,WAVEGEN,DVM,RML
Now the scope comes on normally except that instead of Agilent the Keysight logo is displayed.
My query is below:
1) On power-on it shows - WARNING - Unfinalized Software...Is this normal? or okay?
2) Also displayed just after it turns fully ON is: System Concerns detected: - Instrument is Uncalibrated; Secure Storage is uninitialised. Please set instrument serial and licensing model numbers.
2) How to set the model no? as above?
3) The Waveform Generator function is not working now. ? what to do?
Thanks.
