Hi Guys,
Firstly my apologies for my long absence (A Lot of has happened, Family Issues, People passing away etc) Sometimes life just deals you a really crap hand that lasts for a very long time.
What do you do.
ANYWAY, I'M BACK! (And happy to help anyone who needs a hand through the upgrade process)
Moving forward...
I've read the entire topic over again to catch up and seen that some of you needed my help, Again apologies, but i'm glad you guys ended up upgrading your scope.
I think it's been 10 years since my DS2000A Purchase .
I WANT TO TRY AND UPGRADE MY SCOPE FROM MY SCOPES CURRENT VERSION 00.02.01 TO THE LATEST VERSION 03.06.00.00I can confirm that
- My scope was unlocked 1 year ago with the full options and 300MHz Bandwidth Successfully (as per the first post on this topic).
- Currently my scope is on the following version (Same as 1 year ago)
SYSTEM INFORMATION
Manufacturer: Rigol Technologies
Model: DS2302A
Serial: DS2D160000000
Software Version:
00.02.01 Hardware Version: 2.0
I am currently planning on updating through 11 Versions to see if they all retain the software unlock options.
I plan to go through all the versions 1 by 1 (The idea is to the confirm that they can all be upgraded without losing the options)
NOTE : I do not know if you can upgrade straight from 00.02.01 to 03_06_00_00, I'm going through them incrementally 1 by 1.
I OBTAINED THE FILES FROM THIS URL.
https://www.gotroot.ca/rigol/[/color]]https://www.gotroot.ca/rigol/I Plan to update through the following versions.
the name of the left is the file name , the name on the right is what actually appears in your scope after the update
FILE NAME - ACTUAL VERSION NAME
DS2000-03_00_00_00 - 00.03.00
DS2000-03_00_01_03 - 00.03.00.SP1
DS2000-03_01_00_04 - 00.03.01
DS2000-03_03_01_00 - 00.03.03.SP1
DS2000-03_03_02_06 - 00.03.03.SP2
DS2000-03_04_01_00 - 00.03.04.SP1
DS2000-03_04_02_01 - 00.03.04.SP2
DS2000-03_05_00_01 - 00.03.05
DS2000-03_05_03_03 - 00.03.05.SP3
DS2000-03_05_04_00 - 00.03.05.SP4
DS2000-03_06_00_00 - 00.03.06
At the bottom of this post i will post the release notes for each version (if you're interested).
And i have attached instructions on how to factory default the scope (should you need it to downgrade)
HERE WE GO...
UPGRADE 1 - FROM
00.02.01 TO
00.03.00 - SUCCESSFULLY UPGRADED, ALL OPTIONS INTACT AND PRESERVED
UPGRADE 2 - FROM
00.03.00 TO
00.03.00.SP1 - SUCCESSFULLY UPGRADED, ALL OPTIONS INTACT AND PRESERVED
UPGRADE 3 - FROM
00.03.00.SP1TO
00.03.01 - SUCCESSFULLY UPGRADED, ALL OPTIONS INTACT AND PRESERVED
UPGRADE 4 - FROM
00.03.01 TO
00.03.03.SP1 - SUCCESSFULLY UPGRADED, ALL OPTIONS INTACT AND PRESERVED
UPGRADE 5 - FROM
00.03.03.SP1 TO
00.03.03.SP2 - SUCCESSFULLY UPGRADED, ALL OPTIONS INTACT AND PRESERVED
UPGRADE 6 - FROM
00.03.03.SP2 TO
00.03.04.SP1 - SUCCESSFULLY UPGRADED, ALL OPTIONS INTACT AND PRESERVED
UPGRADE 7 - FROM
00.03.04.SP1 TO
00.03.04.SP2 - SUCCESSFULLY UPGRADED, ALL OPTIONS INTACT AND PRESERVED
UPGRADE 8 - FROM
00.03.04.SP2 TO
00.03.05 - SUCCESSFULLY UPGRADED, ALL OPTIONS INTACT AND PRESERVED
UPGRADE 9 - FROM
00.03.05 TO
00.03.05.SP3 - SUCCESSFULLY UPGRADED, ALL OPTIONS INTACT AND PRESERVED
UPGRADE 10 - FROM
00.03.05.SP3 TO
00.03.05.SP4 - SUCCESSFULLY UPGRADED, ALL OPTIONS INTACT AND PRESERVED
UPGRADE 11 - FROM
00.03.05.SP4 TO
00.03.06 - SUCCESSFULLY UPGRADED, ALL OPTIONS INTACT AND PRESERVED
I have attached
- A Photo of the options After the first upgrade to version 00.03.00 to show they have been preserved
- A Photo of the upgrade screen at version 00.03.00
I have not bothered to upload each and every version picture , However
- A Photo of the last Upgrade , The Options list has been preserved at Version 00.03.06
- A Photo of the upgrade screen at Version 00.03.06
IN SUMMARY - So long as the scope is unlocked , it appears that you can upgrade through all the upgrade versions without losing the installed Options.
I didn't have any problems other than 1.
Initially i used a USB Stick that was 16GB and formatted FAT32, this didn't detect.
I then changed to a USB Stick that was 8GB and formatted FAT32 and this worked without a problem
So Guys, Feel free to upgrade to the latest version
Lastly, of course i did a restart
and i did a system calibration
HERE ARE THE RELEASE NOTES
[Supported Model] All the MSO/DS2000A Series Digital Oscilloscopes
[Latest Revision Date] 2019/01/29
[Updated Contents]
v00.03.06.00.00 2019/01/29
- Fixed the bug of wave displaying after AUTO
[History]
v00.03.05.04.00 2018/04/02
- Inproved the wave updating
v00.03.05.03.03 2017/06/26
- Add new models of DS2102E and DS2202E
- Fixed the error of some Traditional Chinese menu
- Fixed the bug of EDU version
- Fixed the bug of wave stop updating
v00.03.05.00.01 2016/07/20
- Modified the naming rule for saving screen snap
- Fixed the bug of the wave stop updating
- Fixed the bug of Math expression
v00.03.04.02.01 2015/12/14
- Fixed the sensitivity in EXT trigger mode
v00.03.04.01.00 2015/10/10
- Supporting the EDU models for education market
- Standard with 28/56M memory depth and advance triggers options in EDU
models
- Opening the interface for replacing the Logo by AE in EDU models
- Fixed the scope freeze when changing the timebase in high-resolution mode
v00.03.03.02.06 2015/06/17
- Added the persistence of XY wave
- Added the French language menu
- Supporting the license file installed by U DISK
- Supporting the installation of bandle option
- Optimized the SCPI command system
- Supporting the remote access to decoded data
- Fixed the bugs of waveform reading
- Fixed image storage
- Improve the stability the LAN interface communication
v00.03.03.01.00 2014/12/25
- Only Setups data can be saved without UDISK inserted
- Update the library of PictBridge
- Update the library of LXI
- Modified some SCPI commands
- Fixed the bugs of picture data saving in the SINGLE trigger mode
v00.03.02.00.00 2014/09/03
- Fixed the invalid measurement when the trigger status is Wait
v00.03.01.00.04 2014/08/22
- The Ultra Station can't download the wave table data
- Fixed the crash issue of using "AUTO" function in decode mode
v00.03.01.00.03 2014/04/15
- Added phase and delay measure of different edge
- Added the setting of power status
- Upgrade LXI driver
- Optimized the storage menu operation
v00.02.01.00.03 2013/11/04
- Added the AUTO disable command
- Added multi-language (German/Korean/Poland/Janpa etc.)
- Fixed offset error when the amplitude of source is over 1.6v
- Fixed the bugs in trigger when it is Pass/Fail mode
- Fixed the bugs in waveform reading
- Optimized the AUTO trigger mode in every horizontal scale
- Fixed bugs in FFT operation
v00.01.01.00.02 2013/06/06
- Added file name when printing screen
- Optimized source setting for DS2000-S series
- Fixed trigger delay in 500uV/div
- Fixed trial license lost when do self-calibration
v00.01.00.00.03 2013/04/01
- Added SCPI command for decoding data
- Optimized the sampling rate in AC or Ext trigger
- Optimized the speed of PNG file storage
- Increased the sampling rate in ROLL mode
- Support DS2000-S series
- Fixed the cursor window error when change cursor mode
- Switched the position of channel in XY mode
