Hey Friends, I've just got my SDS 1104X-E and it came with 8.1.6.1.25 R2 Firmware version. I'm kind of lost which steps should I follow to upgrade it to 200 MHz. If you can point me out that'd be great. Thanks! Also https://www.makermatrix.com/ is down.
Should your still be in need of instructions, I can point you in the right direction after getting back from work.
I've done it for my own scope and it worked a treat. It's rather straightforward thanks to a handy python script that does all the heavy lifting for you. My thanks to the author, by the way.
I clipped notes took from this thread. It all worked for me.
The heavy lifting of making it all happen is of the folks smarter than I of this thread. (thx!)
Again, just my notes taken from the thread.
Worked so well, bought a 2nd scope... great sales tool..
(Sorry to the OG posters of the content, I copied and pasted txt to note pad, but never took notes of the poster, just the content)..
breaking out important links:
https://replit.com/@wgoeo/siglent-keygenhttps://www.programiz.com/python-programming/online-compiler/WIFI module that worked for me..
https://www.amazon.com/gp/product/B008IFXQFU/refclipped
Hi all,
thanks for this excellent work.
Just bought a SDS1104X-E.
Software Version: 8.1.6.1.35R2
For all that wan't to know if it's still possible, to recover your keys in a case of an emergency (lost receipt etc.): yes!
I can confirm, that using this
https://replit.com/@wgoeo/siglent-keygen script, which I ran locally on my PC using Python 3.9 interpreter, works like a charm.
Enter in the script header:
- the SCOPE-ID without dashes, spaces etc (just numbers and lowercase letters), which you can obtain via the SCPI web interface using the command > SCOPEID? (without the leading >)
- The SN, which you can see at the web interface of the scope at the start page (connect your scope via LAN or WLAN).
The 200M option needs to be entered via the SCPI web interfaces using the command > MCBD XXXXYYYYYY (without the leading > and XXXXYYYYYY being the output of the above python script in the line starting with "200M")
The other options (AWG; WIFI, MSO) need to entered via the UI of the scope. Printing them out like this AAAA BBB CCCC DDDD make life a lot easier, since you need to enter them in blocks of 4.
Using this TP-Link stick will result in a working Wifi:
https://www.tp-link.com/en/home-networking/adapter/tl-wn725n/---------------
clipped
In the 200M line the script will return a key of 16 characters. Copy them.
Back in the web browser on the web page for the scope, in the SCPI command enter:MCBD (key)
Don't include the ()s, just the 16 characters like this: MCBD 0123456789ABCDEF
MCBD YS97TM3YVEUFICEC
8 ) Enter 16 character Scope ID (remove the dashes inbetween!) and the 14 character serial number in the corresponding placeholders of the py-code file.
9) Run the Python code, either on your PC if you have PyCharm or Visual Studio or find an online Python engine where you can paste the patched py code and run it. Most simple is to just run it off the website provided by wgeoe. There you can also paste your ID/SN in.
10) Pick the for the SDS1000X-E relevant keys from the result (100M, 200M, AWG, WIFI, MSO).
11) Go back to the SPCI terminal and install the bandwidth key with MCBD <key> (e.g. MCBD 0123456789ABCDEF). If the key was taken you will see with MCBD?. Then the same key you just entered appears in the result window. Also you can see instantly that the scope has now changed model number. (No scope restart is needed, result is immediate. You even see the change in noise when in the 0.5mV range with nothing connected).
12) Now install the SW options. On the SPCI use LCISL <option> <key> (Option AWG, WIFI, MSO), (e.g. LCISL WIFI 0123456789ABCDE). I used the scope's function to enter the key under Utilities, Options, on one of the pages select one of the three options and press install button to enter the key, scope will answer "License key installed" (make sure the key is correct, I fell victim to my own handwriting and almost gave up until I noticed that I mistook Z for a 2
13) Although changes are imminent, for sanity reboot the scope and do a calibration.
14) Congratulations you are done. Don't forget to thank
wgoeo and tinhead-----------
