WGoeo's old passive k-gen script hack confirmed still fully working on a brand new SDS1104X-EJust note here to save some folks a little time and a few headaches.
I got a brand new SDS1104X-E a-few days back with a recent manufacturing date, ALL the SDS1000 series keys which WGoeo's script generates work just fine.
(I expect on this software/hardware revision that it will always work)
(SW:6.1.35R2 (Release Date 03.07.20) - Uboot: 8.1 - FPGA: 2019-11-15 - HW: 01-04)
Thing is, a few things along the way will likely catch some folks out, so i will detail those below:
* Firstly, when you run the script in rep.it you *must* (it seems) Fork it to run the code with the correct, valid ID & SN actually going thru the compiler (it doesnt seem to compile what it displays if you edit it in your session).
https://repl.it/@wgoeo/siglent-keygen#main.pyWhen you are done running it in a fork, you can then delete it from your account.
* Secondly, whilst the MCBD command to modify MHz rating of the scope does indeed work in the SCPI terminal over the network, you will need to enter the remaining keys for AWG, WIFI & MSO as below:
Use the Options menu directly on the scope to enter the keys, make sure the key TYPE you are entering is shown on the left softkey before you open the menu. Be SURE to select CAPS mode for entering the key (by intensity adj. scrolling to the end option & clicking), then enter your keys one at a time, changing the type entered in the previous menu as and when needed.
Now everything should show as activated.
Enjoy
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
