Author Topic: Unlocking Siglent SDS1104X-E, step by step  (Read 220668 times)
0 Members and 11 Guests are viewing this topic.
Offline TXJD
Re: Unlocking Siglent SDS1104X-E, step by step
« Reply #475 on: November 04, 2023, 02:46:59 am »
I see that there are procedures to revert to the original 100Mhz, and also delete the entitlements (WIFI, etc).  How about a complete factory reset, including Startup Times?  Is there a way to complete erase all logs, etc.?  Essentially bring the scope back to factory virgin configuration.
« Reply #476 on: November 04, 2023, 03:28:24 am »
Welcome to the forum.
Not available to the public.
Why, whom are you trying to deceive ?  :-//
There is a Secure Erase feature that deletes all user settings, IP, WiFi passwords etc.
Out of office and unavailable for a few days.
Online BillyO
« Reply #477 on: November 04, 2023, 03:41:52 am »
Well.  That begs the question .. why?
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
« Reply #478 on: November 04, 2023, 04:27:37 am »
It's just not needed when you have Factory Default and Secure Erase.
All that remains is the preexisting boot count and any options licenses.
Online BillyO
« Reply #479 on: November 04, 2023, 04:29:02 am »
Good enough. :-+
« Reply #480 on: November 04, 2023, 04:45:26 am »
Good enough. :-+
Nearly.
When we have a new unit that is not up to date with the OS and FW we can easy put a few boots on it before PD checks are finished and it's not a good look when a customer receives one with say 4 boots on it already so then and only then do we return it to zero.
3 units just PD checked didn't require such as they all were right up to date so they go out the door with just a single boot on them.  :phew:
Online BillyO
« Reply #481 on: November 04, 2023, 04:51:16 am »
Nearly.
I meant your reply.  I can see why the channel needs this and understand why we don't. :-+
Offline TXJD
« Reply #482 on: November 04, 2023, 02:12:11 pm »
Thanks for the Welcome!  Not  trying to deceive anyone, but I did buy an Amazon Warehouse deal returned/used SDS1104; came without factory packaging.  Looks new, and upon bootup it came up with Startup Times as 1.  However some of the sundries did look used.  Amazon usually doesn't do much cleanup of returns before selling, so wondering if the previous purchaser reset the counter.
« Last Edit: November 04, 2023, 02:36:33 pm by TXJD »
« Reply #483 on: November 04, 2023, 06:43:48 pm »
Interesting puzzle.
TBH it's quite fiddly to get probes and such back into their pouch so they look like new.
What matters is everything working as it should ?
Offline TXJD
« Reply #484 on: November 04, 2023, 07:21:08 pm »
Interesting puzzle.
So far so good :).  I knew I as poking the bear asking the question once I hit send, but had to ask.  Bringing the scope up to latest images, I see the FPGA Version states 2021-11-8.  Running software version 6.1.37R10.  Looks like I'm good with latest code.
Offline nokin
  • Country: vn
« Reply #485 on: November 13, 2023, 08:55:45 am »
How can I get my sds1102x-e's Scope-id ? Telnet spci command <SCOPEID?> returns nothing.
I need ScopeID and SN for generating key 200MHz.
Thank you !
Offline 807
« Reply #486 on: November 13, 2023, 11:49:44 am »
Thank you !
Do you mean 1104X-E?
Does it display "Command send success" in the response box?
Do you get a response from other queries such as "MENU?" It should respond with MENU ON or MENU OFF.
You are clicking on the blue box under the command box afterwards? My initial reaction was to press the enter key which, of course, doesn't work.
« Last Edit: November 13, 2023, 12:12:46 pm by 807 »
Offline nokin
  • Country: vn
« Reply #487 on: November 14, 2023, 12:12:45 am »
Mine is SDS1102X-C and converted to SDS1102X-E for full langugage support then now I want unlock it to 200MHz.
The response look like this ... SCOPEID? gave nothing. Others command are ok.
« Reply #488 on: November 14, 2023, 12:39:47 am »
Syntax is incorrect.
Try SCOPE_ID?
The following users thanked this post: nokin
Offline modoran
« Reply #489 on: November 14, 2023, 10:03:03 am »
Why not use web browser as everybody else ?
Offline nokin
  • Country: vn
« Reply #490 on: November 14, 2023, 11:08:10 am »
2 channels series are not supported this function. Only for 4 chs.
« Last Edit: November 14, 2023, 11:10:30 am by nokin »
Offline nokin
  • Country: vn
« Reply #491 on: November 14, 2023, 11:13:03 am »
Try SCOPE_ID?
I wonder why with new firmware from 1.3.36 or 1.3.37 Telnet cannot open port to scope anymore.
I need re-up back to old fw for hacking then upgrade later.
Offline nokin
  • Country: vn
« Reply #492 on: November 14, 2023, 02:00:33 pm »
Try SCOPE_ID?
Thank you again, tautech !
follow this post, he said "SCOPEID?"
https://www.eevblog.com/forum/testgear/unlocking-siglent-sds1104x-e-step-by-step/msg4066828/#msg4066828
follow this post, Othman he said "SCOPEID?" again and gave nothing
https://www.eevblog.com/forum/testgear/siglent-sds1102x-c-supported-languages-issue/msg4381981/#msg4381981
so I did the same thing and thought maybe something wrong or cannot get ID with this series...  :phew:
Now I've unlocked successful and mine is SDS1202X-E with -C- hardware based  :-DD
Offline 807
« Reply #493 on: November 15, 2023, 08:54:46 am »
...You are clicking on the blue box under the command box afterwards? My initial reaction was to press the enter key which, of course, doesn't work.
Sorry. Should have read your post more closely. I assumed that you were using the web interface.
btw...scopeid? & scope_id? both work on the 1104X-E.
Offline nokin
  • Country: vn
« Reply #494 on: November 16, 2023, 12:12:19 am »
I've tried on EasyScope last night (2 channels is not supported Web sever).
Yes, scopeid? & scope_id? both worked !
But on Telnet only scope_id? ok.
As you see the pic I attached above, scopei? command returns none result.
« Last Edit: November 16, 2023, 12:17:53 am by nokin »
Offline memyselfi
  • Country: pt
« Reply #495 on: December 01, 2023, 04:14:49 pm »
Just for sharing python script method still working fine for a new SDS1104X-E. The process works fine. Latest firmare. also.
Offline mainman
« Reply #496 on: January 11, 2024, 01:40:44 am »
Hello does the script method still work. Did Siglent block this exploit as of 2024.
Offline pope
« Reply #497 on: January 11, 2024, 07:44:20 am »
Why would they?
Offline memyselfi
  • Country: pt
« Reply #498 on: January 31, 2024, 11:19:15 am »
Hi. Sorry for the late reply.
Yes, for me it worked super smoothly, using the information shared along these posts (via python script and scopeid).
Firmware file (latest) => SDS1xx4X-E_6.1.35R2_EN.zip
Uboot-OS Version: 8.3
Hardware Version: 09-08
Product Type: SDS1104X-E
Also enabled and using Wifi dongle TL-WN725N V3, bought from local reseller for <6€
« Last Edit: January 31, 2024, 11:20:54 am by memyselfi »
Offline Cauf
« Reply #499 on: January 31, 2024, 12:32:50 pm »
Another one Unlocked today.   :-+
With special thanks to Martin72 for the guidance.
