Author Topic: UNI-T UTG932/UTG962 200MSa/s Function Arbitrary Waveform Generator  (Read 136292 times)
0 Members and 11 Guests are viewing this topic.
Offline ptluis
  • Country: pt
Re: UNI-T UTG932/UTG962 200MSa/s Function Arbitrary Waveform Generator
« Reply #300 on: February 04, 2022, 09:33:35 pm »
I think I might have broke my utg932 by poking around a bit too much in the eeprom
Would you mind attaching your bin file for me to re flash mine please?
I can’t seem to activate the FM modulator  :(
My friend i only saved the following format (address, Hex, ascii) because my programming software recognizes this type of data.
It is the full content of the UTG932
See if you can rebuilt yours from the hex values.
At the end of the code (UTG900;**;60;1)  "60" means 60MHz version, "30" means 30MHz version
!!!! I don't know why the forum software insists in converting the ascii part of the "www.uni-" into an url link.  !!!!
Although the hex values are correct
Address 00007980 should be read like:
00007980 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 77 77 77 2E 75 6E 69 2D ....................www.uni-
I remember in having some problems flashing the eeprom, if I just changed the 30 to 60 and reflash the eeprom it got corrupted, but if I erase it first and then do a full write, it works 100%
00000000 55 54 47 39 4A 75 6C 20 32 32 20 32 30 32 30 20 31 34 3A 35 35 3A 30 38 00 00 00 00 UTG9Jul 22 2020 14:55:08....
00000028 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 88 C3 40 00 00 01 00 00 00 00 00 ...................@........
00000056 00 00 00 00 38 9C 7C 41 DB 74 28 67 4C E5 61 3E 00 00 00 00 65 CD 9D 41 2B 69 A4 29 ....8.|A.t(gL.a>....e..A+i.)
00000084 2B 1B 50 3E 2B 69 A4 29 2B 1B 50 3E 72 1C C7 71 1C C7 11 40 72 1C C7 71 1C C7 11 C0 +.P>+i.)+.P>r..q...@r..q....
00000112 00 00 00 00 00 00 08 40 A1 9C A3 5D 19 FA 22 C0 D9 6C DF CC 76 F8 F0 3F 00 00 00 00 .......@...].."..l..v..?....
00000140 00 00 F8 3F 00 00 00 00 00 00 08 40 00 00 00 00 00 00 00 00 00 00 34 42 FA ED EB 39 ...?.......@..........4B...9
00000168 00 00 00 00 00 00 00 00 00 00 00 13 01 00 00 00 00 00 00 00 00 00 14 40 00 00 00 00 .......................@....
00000196 00 88 D3 40 00 00 00 00 00 40 8F 40 00 00 A0 42 00 00 34 43 00 00 00 00 00 00 69 40 ...@.....@.@...B..4C......i@
00000224 FC A9 F1 D2 4D 62 50 3F 00 00 00 00 00 88 C3 40 00 00 00 00 00 88 C3 40 00 00 34 43 ....MbP?.......@.......@..4C
00000252 00 00 00 00 00 00 00 01 01 01 00 00 00 00 00 00 00 88 C3 40 00 00 01 01 00 00 00 00 ...................@........
00000280 00 00 00 00 18 FB 64 41 88 59 F1 A3 39 67 78 3E 00 00 00 00 65 CD 9D 41 2B 69 A4 29 ......dA.Y..9gx>....e..A+i.)
00000308 2B 1B 50 3E 2B 69 A4 29 2B 1B 50 3E AA AA AA AA AA AA FA 3F AA AA AA AA AA AA FA BF +.P>+i.)+.P>.......?........
00000336 00 00 00 00 00 00 10 40 02 4F 71 B6 CF D5 0F C0 00 00 00 00 00 00 00 40 00 00 00 00 .......@.Oq............@....
00000364 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 C0 00 00 48 42 CD 39 43 33 ...........@..........HB.9C3
00000392 00 00 00 00 00 00 48 42 00 00 01 00 00 00 00 00 9A 99 99 99 99 99 B9 3F 00 00 00 00 ......HB...............?....
00000420 00 40 8F 40 00 00 00 00 00 88 D3 40 00 00 A0 42 00 00 34 43 00 00 00 00 00 00 69 40 .@.@.......@...B..4C......i@
00000448 FC A9 F1 D2 4D 62 50 3F 00 00 00 00 00 40 8F 40 00 00 00 00 00 88 C3 40 00 00 34 43 ....MbP?.....@.@.......@..4C
00000476 00 00 00 00 00 01 02 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ............................
00000504 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000532 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000560 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000588 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000616 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000644 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000672 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000700 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000728 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000756 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000784 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000812 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000840 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000868 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000896 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000924 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000952 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00000980 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001008 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001036 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001064 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001092 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001120 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001148 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001176 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001204 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001232 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001260 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001288 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001316 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001344 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001372 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001400 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001428 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001456 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001484 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001512 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001540 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001568 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001596 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001624 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001652 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001680 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001708 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001736 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001764 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001792 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001820 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001848 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001876 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001904 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001932 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001960 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00001988 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002016 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002044 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002072 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002100 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002128 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002156 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002184 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002212 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002240 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002268 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002296 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002324 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002352 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002380 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002408 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002436 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002464 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002492 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002520 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002548 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002576 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002604 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002632 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002660 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002688 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002716 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002744 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002772 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002800 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002828 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002856 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002884 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002912 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002940 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002968 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00002996 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003024 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003052 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003108 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003136 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003164 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003192 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003220 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003248 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003276 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003304 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003332 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003360 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003388 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003416 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003444 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003472 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003500 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003528 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003556 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003584 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003612 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003640 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003668 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003696 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003724 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003752 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003780 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003808 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003836 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003864 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003892 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003920 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003948 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00003976 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004004 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004032 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004088 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004116 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004144 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004172 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004200 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004228 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004256 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004284 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004312 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004340 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004368 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004396 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004424 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004452 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004480 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004508 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004536 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004564 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004592 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004620 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004648 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004676 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004704 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004732 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004760 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004788 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004816 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004844 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004872 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004900 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004928 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004956 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00004984 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005012 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005068 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005096 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005124 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005152 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005180 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005208 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005236 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005264 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005292 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005320 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005348 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005376 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005404 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005432 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005460 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005488 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005516 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005544 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005572 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005600 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005628 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005656 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005684 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005712 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005740 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005768 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005796 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005824 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005852 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005880 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005908 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005936 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005964 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00005992 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006048 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006076 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006104 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006132 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006160 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006188 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006216 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006244 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006272 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006300 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006328 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006356 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006384 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006412 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006440 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006468 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006496 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006524 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006552 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006580 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006608 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006636 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006664 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006692 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006720 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006748 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006776 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006804 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006832 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006860 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006888 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006916 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006944 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00006972 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007000 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007028 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007056 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007084 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007112 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007140 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007168 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007196 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007224 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007252 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007280 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007308 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007336 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007364 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007392 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007420 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007448 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007476 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007504 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007532 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007560 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007588 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007616 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007644 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007672 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007700 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007728 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007756 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007784 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007812 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007840 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007868 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007896 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00007924 FF FF FF FF FF FF FF FF FF FF FF FF 55 54 47 39 30 30 3B 2A 2A 3B 36 30 3B 31 2E 30 ............UTG900;**;60;1.0
00007952 31 3B 31 2E 30 30 3B 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1;1.00;.....................
00007980 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 77 77 77 2E 75 6E 69 2D ....................[url=http://www.uni-]www.uni-[/url]
00008008 74 72 65 6E 64 2E 63 6F 6D 0A 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 trend.com...................
00008036 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ............................
00008064 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00008092 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00008120 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00008148 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ............................
00008176 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF                                     ................
The following users thanked this post: DaneLaw, Dandymon
Offline Dandymon
« Reply #301 on: February 06, 2022, 04:14:44 pm »
ptluis, my hero. You’re a lovely man, but believe it or not it didn’t fix it because I’m a bit of a silly man myself sometimes; and it appears my waveform generator was never broke.
The problem was that I had set a carrier to 60MHz and tried to use FM, whereby the frequency would go over 60MHz if the frequency was to modulate at this limit. This was the reason I couldn’t set any deviation, there is a HARD stop on 60MHz, and if I set it at 59MHz, I can use FM. Makes sense when you think about it.
Sorry to have wasted your time, however your contribution to this message board will undoubtedly help others in the future.
Thanks
Offline wasedadoc
« Reply #302 on: February 06, 2022, 10:57:03 pm »
Is the complete firmware really only 8192 bytes of which less than about 550 are not 0xFF ?
Offline ledtester
« Reply #303 on: February 06, 2022, 11:37:46 pm »
I think it's just used to store configuration and user preferences.
Offline ptluis
  • Country: pt
« Reply #304 on: February 07, 2022, 10:07:37 pm »
This is not the firmware, only de contents of the eprom used to store the user settings and the configuration of the device model. I tried to modify some values around the data trying to expose some kind of hidden functions, but since I don't have a spare eprom around I had to stop trying because I'm unable to test the changes without first erase and do a full write. This takes a lot of time and reduces eprom life.
Offline ptluis
  • Country: pt
« Reply #305 on: February 07, 2022, 10:09:47 pm »
Thanks
Good to know everything is fine, anyway I leave the code above for those who have corrupted eprom and to be able to revive the device.
Offline Yuriy V.
  • Country: ru
    • trengtor custom
« Reply #306 on: February 19, 2022, 07:32:31 am »
This generator start fails from time to time. It looks like this:
When the generator is running for a long time, some kind of relay clicks in it and the output signal disappears. The exit indicator does not turn off. After a short time, random flickering of the button backlight starts. The screen backlight does not flicker. After switching off and on, the generator works again, until the next failure.
Does anyone have similar problems?
« Last Edit: February 19, 2022, 03:42:57 pm by Yuriy V. »
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
« Reply #307 on: February 19, 2022, 09:56:44 am »
Make sure you are not exceeding the max output power . Ie if you have a 50 ohm dummy load and running the output higher than 10v . . Just a thought.  It does have overload protection.
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
Offline Yuriy V.
  • Country: ru
    • trengtor custom
« Reply #308 on: February 19, 2022, 12:38:00 pm »
Defenitely not. It can happen even when monitoring the output with an oscilloscope, without any load.
1 KHz, 400 mVp/p, 1 MOhm etc.
And note:
« Last Edit: February 19, 2022, 03:43:07 pm by Yuriy V. »
Offline valcher
  • Country: ru
« Reply #309 on: February 19, 2022, 04:58:48 pm »
Hi all!
I don’t know if I discovered America, maybe it was already somewhere, but if you hold down the “Utility” button on the generator turned off and turn on the power, then an invitation appears on the screen - “Place Upgrade!”. As I understand it, there may be updates for the device.
I have SW - 1.09, what versions do you have?
Offline Yuriy V.
  • Country: ru
    • trengtor custom
« Reply #310 on: February 19, 2022, 05:18:18 pm »
1.07
Offline valcher
  • Country: ru
« Reply #311 on: February 19, 2022, 05:26:25 pm »
Now it remains to find out how to unload the firmware without opening the generator. :)
Offline Labrat101
  • Regular
« Reply #312 on: February 19, 2022, 06:58:43 pm »
Hi all!
That is mentioned in the full documentation . but there has not been any updates  :(  .
Offline Labrat101
  • Regular
« Reply #313 on: February 19, 2022, 07:01:58 pm »
 :palm: O yes it does and it works very well ..
« Last Edit: February 19, 2022, 07:05:16 pm by Labrat101 »
Offline Yuriy V.
  • Country: ru
    • trengtor custom
« Reply #314 on: February 19, 2022, 08:36:16 pm »
In my opinion, it looks more like some kind of problem with the built-in DC-DC power converter (overheating & microcracks). This is indirectly indicated by the flickering (not blinking) of the LED backlighting of the buttons. And the relay also can release due to a voltage drop.
« Last Edit: February 19, 2022, 08:46:34 pm by Yuriy V. »
Offline Felipe Lacerda
  • Country: br
« Reply #315 on: April 05, 2022, 05:20:37 am »
Just this change needed to unlock the 60mhz in model 932e?
Is it possible to backup the file with a CH340(3.3v)?
Offline JOSM
« Reply #316 on: April 06, 2022, 08:32:18 am »
Yes, that will do it.
Offline Mario87
« Reply #317 on: April 15, 2022, 10:21:13 am »
Hi all,
Thinking of picking up one of these, but does anyone know, when purchasing from BangGood, does it come with a UK power adapter? From what I have seen it comes with one of those universal adapters where you select the plug type you want in click it in place, but not seen any images or videos that show the UK plug adapter??
Offline ledtester
« Reply #318 on: April 15, 2022, 02:40:59 pm »
Hi all,
In the Q&A section for the product I found this:
but you might want to confirm with Banggood just to be sure.
Offline 123rolle
« Reply #319 on: May 18, 2022, 07:35:29 pm »
I guess for the current prices JUNTEK PSG9080 184€ (shipped) is a lot better deal than UNI-T UTG932 (even can be hacked) for 145€ shipped?
Offline hughtmccullough
« Reply #320 on: June 03, 2022, 03:51:28 pm »
I am thinking of buying one of these but there is one requirement I have that I am not sure about.
Reading through this thread and information on other sites it seems that it is perfectly possible to upload arbitrary waveforms to the generator.  I understand that the waveforms aren't persistent and I'm happy to upload each time I use it.  I use Linux on my PC and have read that there is a method for uploading using Python based software and that it is possible to upload CSV files.  However, I haven't spotted any tools for creating the waveforms that are all that good.  What I would like to be able to do is create a list of 4096 data points in a spreadsheet, convert those to a CSV file with any appropriate header information and upload the resulting CSV file to the generator.
Is it possible to do this?
If so, what header information/formatting is required in the CSV file?
Is a single list of numbers enough or do the points have to be input as pairs?
If so, what is needed for the time coordinate as the frequency can obviously be varied in use?
Is there a Linux tool that can create files based on my spreadsheet results in a format other than CSV that would be a better way of doing this?
Offline ledtester
« Reply #321 on: June 03, 2022, 04:45:03 pm »
The exact format of the .csv file might depend on the program you use.
This python program:
https://github.com/jarjuk/UTG900
looks like it could support csv as well as other formats. Here is the documentation for the arb upload command:
https://github.com/jarjuk/UTG900#arb---upload-wave-file-and-use-it-to-generate-wave
and if you look in the data directory:
https://github.com/jarjuk/UTG900/tree/main/data
you'll see an example .bsv file as well as a .csv file.
I would just ask the developer (by email or open a github issue) for specifics on how to generate waveform files for use with the program.
« Reply #322 on: June 03, 2022, 09:52:44 pm »
Thanks.  That was exactly what I wanted.  It looks as if it will do my job.  Now I need to get one.
Offline Git
  • Very old engineer with over 4 decades in design.
« Reply #323 on: June 20, 2022, 09:46:54 am »
If you are looking for a UT962E in the UK, there are none at the moment unless you want to spend well over the odds on Ebay. After a search, an order then cancellation with Banggood, I eventually got one from Aliexpress. There's a genuine UNI-T store on there and several other sellers. UNI-T are using a fairly slow transport with no other choice, but one seller redistributes from France and Spain, with a delivery estimate of delivery of 16 days. Banggood offered fast expedited carriage for free. I ordered and the order status said Standard carriage which is over a month. Not the first time this has happened to me there, so I cancelled and went to Ali. I don't know if it is still the case, but the suffix E on the model number is for English, no suffix is for the Chinese language model. A post in this thread suggested the firmware is now multilingual. Good luck. Don't forget the VAT :(
« Last Edit: June 21, 2022, 02:24:42 pm by Git »
Offline XenonEng
« Reply #324 on: August 18, 2022, 09:38:03 pm »
I registered just to say thanks to all who discovered/implemented the hack. I now have a lovely 60Mhz func gen to replace (supplement) my ancient LFM3!
Regarding the power consumption of the unit, I noticed the current draw is around 0.8A (rising to 1A with outputs on into 50 ohms) BUT if I connect the outputs to earth referenced BNC of my oscilloscope then the current drops to 0.48A (0.56 with both outputs into 50 ohms.)
Can someone explain that one for me?
Cheers all.
