Author Topic: 121GW strange range/socket problem  (Read 1580 times)
Morg and 1 Guest are viewing this topic.
Online MorgTopic starter
Re: 121GW strange range/socket problem
« Reply #25 on: August 26, 2024, 09:55:11 am »
If flexing the jack a certain way solves the issue, then just keep doing that while you hunt?
While hunting, the DMM is off, so I can't "hunt" for real, just try to find non-connections where connections should be. I couldn't find any so far...? So flexing couldn't make it better... I am a bit confused about this.
Also, it looks like the sense connection for the mA/uA jack goes into an inner layer of the PCB then goes under the selector?  Does pressing on the selector make any difference?
The rotating selector? No, nothing.
