Hi All,
I have added a couple of internal pictures to the UT-81B to the review thread that is already running if anyone is interested.
I am also attaching a couple of pictures I have of the UT-804 internals to this message.
The poor terminal contact construction using self tapping screws is visible on the right hand side of the front panel picture. Sadly I cannot find any pictures of the front panel PCB itself.... I think I had given up on the UT-804 by then !
You sure get a lot of fresh air for your money with this unit but maybe that's just large scale integration for you
I personally think it is probably a very similar design to many of the UNI-T handheld multimeters, just in a bench case and more money.
I ended up buying two used Fluke 8840A bench multimeters with the AC RMS and GPIB options fitted. When you look inside those Fluke units you get a feeling of true quality. They may be old but by heck they were built well and they have software configured calibration.... no mechanical pots to adjust
Accuracy was excellent when tested against my employers standards.
Regards
Fraser
