So did you manage to fit a 10x38 overly-tight or what? Actually i'm looking to put just a 6x32mm because after all, blowing up mA fuses is far more common than blowing up A fuses thus much cheaper and i don't think you would be using mA too much on 50kA systems are you
Well that black thing can be two things: MOVs or Sparkgaps
And the fuses appear to be pretty cheap, find them all over in taobao. Is it? I'm not sure
But i'm sure the mods won't cost you that much extra, for the extra safety i'm modifiying BOTH of mine
6x32 or 10x38 i'm not sure ...
But i notice the glaring omission of a input resistor R39 on the UT61E, which is on the PCB but it isn't there! I guess you can't include a input protection resistor when you're measuring 220MHz
Here's a reason to stay away from the VC86E, it's just crap.
At least the mov's included and i bet the buzzer doesn't sound half as good as the UT61E does, plus it lacks relative which is a total deal killer
