Author Topic: UNI-T UT61B vs UT61C  (Read 22651 times)
Offline inquirerTopic starter
« on: October 01, 2014, 03:57:15 pm »
UT61B vs UT61C
Can someone explain what's the difference between these two multimeters? Thanks!
Offline Monkeh
Re: UNI-T UT61B vs UT61C
« Reply #1 on: October 01, 2014, 04:04:11 pm »
The B is 4000 count, the C is 6000 count.
« Reply #2 on: October 01, 2014, 04:09:50 pm »
What does this mean and what about the different ranges in DC and AC voltage and current?
Offline rolycat
« Reply #3 on: October 01, 2014, 04:15:29 pm »
Offline Monkeh
« Reply #4 on: October 01, 2014, 04:16:32 pm »
Those are exactly what it means.
The B will measure up to 40mV with two decimal places, and the C will measure up to 60mV with two decimal places. They drop one digit when moving to 400mV and 600mV respectively, and on up the range.
« Reply #5 on: October 01, 2014, 04:42:27 pm »
Thanks guys!
I watched the video. If I got it right both the c and b have the same accuracy?
Is C better than the B?
« Reply #6 on: October 01, 2014, 05:42:02 pm »
I just saw that E has more counts and better accuracy. So accuracy wise the E is the best unit of the series, right?
Offline rolycat
« Reply #7 on: October 01, 2014, 06:28:10 pm »
Right. The UT61E is generally reckoned to be a decent low cost meter for low voltage hobby use.
The two major omissions are a backlight and temperature measurement.
« Reply #8 on: October 01, 2014, 07:36:39 pm »
It would be nice if the thermometer was included, but I can do without one. As for backlight according to there site it is included: http://www.uni-trend.com/UT61E.html
Offline Monkeh
« Reply #9 on: October 01, 2014, 07:46:13 pm »
Their site lies. It claims auto power-off too.
Offline angelioto007
  • Country: cz
« Reply #10 on: December 22, 2014, 08:39:39 pm »
can you guys please help me? i can´t decide beteween ut61c and ut61d. which one should i buy?
Offline Lightages
  • Canadian po
« Reply #11 on: December 22, 2014, 11:20:24 pm »
I would buy neither. IMHO the UT139C is a much better buy than the UT61B/C/D. It is arguable if you want a PC connection as the UT139C does not do this. It does have a back light, temperature, good input protection, fast continuity, and all the measurements you might want. The UT61E has a fast continuity test whereas the UT61B/C/D do not and it also is more accurate.
If you do not need a PC connection I would strongly suggest the UT139C instead over any of the UT61X series.
« Last Edit: December 23, 2014, 05:09:17 am by Lightages »
Offline Matje
« Reply #12 on: December 22, 2014, 11:24:46 pm »
The one that better fits your requirements and available money - you need to define your requirements obviously. The manuals are available online, read them.
Differences I can see from skimming the manuals:
C: has temperature measurement, has automatic sleep mode
D: has separate AC and DC voltage on rotary switch, has true RMS
So, just decide what is more important to you. ;-)
Offline DanielS
« Reply #13 on: December 23, 2014, 01:35:00 am »
Personally, I got the 61E - I wanted the extra resolution partly as a sanity check for my 3 1/2 multimeters, most of which $5-10 cheapies simply for the convenience of being able to keep tabs on multiple supply voltages and currents at once instead of moving leads around.
The display is fairly readable even under low-light conditions (ex.: scattered light from an LCD in an otherwise unlit room) so unless you need to work in near-total darkness, the lack of backlight should not be much of an issue.
  • Country: cz
« Reply #14 on: December 23, 2014, 10:33:11 pm »
i´ve decided, i´m gonna buy the c type, ´cause i´ll just need it to do low voltage stuff dc mainly, not high voltage and i want to replace my cheapo with something better, i don´t trust my cheapo any more - continuity test sucks on it and manual ranging is just waste of time...
anyway thx guys for your suggestions and tips, really helped me  :-+
Offline Lightages
  • Canadian po
« Reply #15 on: December 23, 2014, 11:18:34 pm »
If I am correct, the C models has a very slow continuity test too. Let us know!
And why would you spend the same money as a UT139C and get something much less well built and not as safe?
http://www.ebay.com/itm/Uni-T-UT139C-True-RMS-Digital-Multimeter-with-Temperature-NCV-Backlight-/171213085325?pt=LH_DefaultDomain_0&hash=item27dd185a8d
« Last Edit: December 23, 2014, 11:31:59 pm by Lightages »
Offline retiredcaps
« Reply #16 on: December 23, 2014, 11:43:59 pm »
C continuity is slow.  See 7:30 into video
Electronupdate is a member here and originally posted
https://www.eevblog.com/forum/testgear/uni-t-ut61c-multimeter-teardown-and-review/
In addition, his UT61C is broken trying to help someone
https://www.eevblog.com/forum/beginners/broken-uni-t-ut61c-or-am-i-missing-something/
And at least one UT61C was shipped with a missing resistor which I helped the OP discover.  :palm:
« Last Edit: December 23, 2014, 11:51:31 pm by retiredcaps »
Offline miguelvp
« Reply #17 on: December 24, 2014, 03:03:14 am »
If you can change the count the continuity test will be faster I think, but don't hold me to it :)
Offline DanielS
« Reply #18 on: December 24, 2014, 11:18:56 am »
The UT61E (the 22 000 counts model) has very fast, quick-latching (as in non-scratchy) continuity testing.
Getting the bundled probes to make good contact for continuity testing can be somewhat irritating though.
