Author Topic: Uni-t UT203 Clamp Multimeter Teardown  (Read 7313 times)
Offline electronupdateTopic starter
« on: March 02, 2013, 06:57:57 pm »
Bought this multimeter for it's ability to measure higher DC currents.  When I tore it down it was better than  I expected... much better than my previous buy of a no-name "CP-05" which was entirely hand soldered. Not really sure where UNI-T fits in the spectrum of quality, but this one seems better than bottom-of-the-barrel, which suprised me as it was only $35.00.
A video of the review at the following link:
Re: Uni-t UT203 Clamp Multimeter Teardown
« Reply #1 on: March 03, 2013, 10:38:34 am »
Very nice, but I would prefer the 204 as it comes with true RMS capability.
Offline Lightages
  • Canadian po
« Reply #2 on: March 03, 2013, 05:32:31 pm »
Of course your needs will determine the model you want! The UT204 has TRMS, but does not have capacitance nor temperature which the UT204A . Who is it that says "horses for courses"?
Offline Mkdsime
  • Country: mk
« Reply #3 on: February 03, 2019, 08:26:00 pm »
Hi i have UT204A clamp meter it fell softly and now when i press the select or rel or hold button it beeps sometimes display goes crazy and shuts down. I have cleaned the connections on the pcb, measured the transistors with diode test directly on the board all 'Y1' SMD transistors have short between 2 pins. What could be the problem if someone knows please help somehow thanks and take care.
