Author Topic: Uni-t ut18c Voltage and continuity tester teardown. Interesting design choices!  (Read 3783 times)
Offline JonnyMTopic starter
I just received my Uni-t 18c voltage and continuity tester from aliexpress. I'm an electrician so voltage and continuity testers are very handy and foolproof for troubleshooting and for proving that a circuit is dead.
Here's some pictures from my teardown:
Back side of L1 probe
The strain relief wasn't properly clamping the cable  :o
Fixed it!
Front side of L1, Two ptc's
Back side of L2 probe.
Front side of L2 probe. It uses a 32bit arm?? :wtf: Isn't it quite overkill for such a simple device?
Offline WhichEnt2
  • Country: ru
At least it doesn't have a trimpot inside, which being substituted by 2 parallel resistors like in the predecessor.
Short pieces, high value, small period, huge amount, long delay.
Offline T3sl4co1l
    • Seven Transistor Labs
ARMs are very cheap.  Might as well save on dev cost!
Seven Transistor Labs, LLC
Offline joeqsmith
Wait, you're an electrician and you are using UNI-T products?  Even if you have to fix them from the factory as you have shown, that's a big endorsement as far as I am concerned.  With a probe like this, I assume you are working in industrial rather than residential, CAT III and up?
I only work in residential areas. Mostly measuring single phase (230v). I haven't ever even needed to measure between two phases. The other option would have been the fluke t110 but my co-workers have had some troubles with them, same problem as this guy: https://www.reddit.com/r/electricians/comments/4qxzbk/fluke_t110_repair/
Here's some pictures of the fluke from the Reddit thread: https://imgur.com/a/KCnLq
It seems that it doesn't have any input protection at all or am I missing something?
« Last Edit: October 07, 2017, 08:09:07 pm by JonnyM »
Good point, I don't think they produce that many, it's not a very popular product.
Offline joeqsmith
Looks like only the one half of multiple meters is shown.   Too bad no one posted their findings.  Would have been interesting to know what the problem was.
Are your co workers all using UNI-T products now as well?
One went back to his fluke 177 and the other one got a Duspol branded voltage and continuity tester, very nice tool and probably robust but it costs 115€.
