Author Topic: Uni-T UT181A and calibration  (Read 9689 times)
Offline JulienS
Re: Uni-T UT181A and calibration
« Reply #25 on: February 25, 2024, 09:49:14 am »
I think I have found a door but we need the key ...
Keeping pressed F2 and F3 pres On/Off button.
And the screen with a 5 zeros appear . This can be modified with arrows to form a code . 00000 as to CEM is not working ...
I will search for key used in other uni-t dmms .
Hi everyone, better late than never ! the key code is 02089.
The following users thanked this post: Bobson, LastManStanding, janiorib, csuhi17
Offline joeqsmith
« Reply #26 on: February 25, 2024, 04:19:42 pm »
I predict an increase in posts about how the UT181A is not accurate.  :-DD
Offline Bobson
  • Country: ru
« Reply #27 on: June 27, 2024, 05:50:02 am »
UT-171B to enter CAL mode turn on while pressing RANGE+STORE. Password is the same, 02089.
However, unlike UT-181A where you just type in proper values, UT-171B shows some CHANGING value at secondary readout, and it is unclear how to change primary value.
The following users thanked this post: skander36
Online stj
« Reply #28 on: June 27, 2024, 12:52:32 pm »
lets apply some logic.
the meter is new.
it was probably calibrated on an automated system before being packed.
it has travelled a long way.
i would open it and look for bad soldering or other physical issues.
Offline Bobson
  • Country: ru
« Reply #29 on: June 27, 2024, 06:33:35 pm »
the meter is new.
How does it correspond to the adjustment protocol?
Online stj
« Reply #30 on: June 29, 2024, 03:07:01 pm »
it doesnt have anything to do with ajustment protocol.
why would you mess up the calibration if it may just be a cracked solder joint?
changing the factory calibration should be the very last option, not the first!
