The UT171 is a new series of DMM from Uni-T. Model "A" is a 40,000-count meter. It can store up to 999 readings in its internal memory. It also comes with a USB cable that allows it to connect to a PC for longer term data logging.
First impressions:
1. Very well built, on par with the newer Uni-T's such as the UT139 and UT181 series.
2. Input protection looks good with properly rated ceramic/HRC fuses.
3. DCV spec'ed at 0.025%+5 counts and based on the references and 34461A I have it is right around the 0.02-0.04% region, so there are only a few counts to spare.
4. Continuity tester isn't the fastest, with a very slight delay, but it is latched. Still quite usable and much better than many slow DMMs.
5. Display update rate is fast at 5 times/sec (according to specifications).
6. Shows "Leads" on display and beeps when leads plugged into the wrong sockets.
7. Backlight is not very bright but perfectly adequate in dimmer environments (very similar to the UT139C).
8. Resistances between the terminals in the A, mA and uA are respectively about 32.77mOhms, 1.67Ohms and 51.16Ohms.
Now here a few pictures (click to see larger version):
