LeonR, agreed, the UT117C's backlight isn't great. I reached for my nearest DMM, an HP-770D, for a side-by-side check. I'd guess the UT117C had about 60-70% of the lumens of the other.
makz, SEL+REL sounds right. As for comparison, I'm not sure what you're asking.
Out of the box, all the DCV and resistance ranges I tested on my UT117C are about six digits off. This is oddly consistent and made me think they copied the EEPROM from another unit without recalibrating
As for some of my other calibrated meters...
The RM303 is rated for better accuracy (0.05%+-3 in DCV) and is now within a digit or two on multiple DCV and resistance ranges after a brief warmup. It's the best resistance accuracy I've seen in a cheap meter so far. I modded the voltage reference but it was nearly as good before this. (Changed ICL8069D to a handpicked ICL8069A with low drift and added a 4.7uF cap across it per datasheet recommendation. Was hoping to get rid of its wobble, 10.000V is 9.999-10.001 every second or two, but the mod only helped a little. Paralleled caps in a few spots also didn't help. Didn't want to try adding a VLCD supply as another modder did.)
The B41T+ is only accurate to 1-2 digits on a short range of DCV. Its linearity as tested across its 2.2-22V range seems a bit off (several digits IIRC) and some other modes don't have their own calibration (no EEPROM, just a few pots). The B41T+ is a good performing meter otherwise, with a fast-responding analog bar graph and fast auto-ranging.
Incidentally, the bar graph on the UT117C is responsive but "noisy", at least during a quick check of around 5.0VDC.
