Author Topic: Uni-T 61E Fuses  (Read 3624 times)
Offline BryanTopic starter
Uni-T 61E Fuses
« on: July 04, 2013, 08:08:25 am »
Anybody know what the replacement fuses for this meter are or a better replacement. Paper manual was in Chinese, and the online manual states
A mA range: F1, 1A H 240V, 6x25mm (CE)
10A range: F2, 10A H 240V, 6x25 mm. (CE)
I can not find fuses that are 6x25mm.  Should they be Fast, Slow, Medium blow?
Don't trust the rated CAT on the meter, so certainly won't use in anything about CAT2 so no point in sourcing out 1000v fuses ;D
-=Bryan=-
Offline Wytnucls
Re: Uni-T 61E Fuses
« Reply #1 on: July 04, 2013, 08:45:48 am »
Just put any fast blow 250V fuse that fits in there and you'll be fine or buy a few of the original ones on the internet.
Offline Lightages
  • Canadian po
Re: Uni-T 61E Fuses
« Reply #2 on: July 04, 2013, 05:19:54 pm »
Offline Monkeh
Re: Uni-T 61E Fuses
« Reply #3 on: July 04, 2013, 05:45:16 pm »
It's written on the fuses: BS1362. They're easily found.
« Last Edit: July 04, 2013, 06:35:46 pm by Monkeh »
alm
  • Guest
Re: Uni-T 61E Fuses
« Reply #4 on: July 04, 2013, 06:02:11 pm »
In the UK at least, but also in wherever Bryan is from (presumably the Antarctic). BS1363 plugs are not very common outside the UK, so I'm guessing the fuses might not be either.
