I was reading a bit more, so I need fuses only when I have a device where I can measure amps with the probes? Which is not the case with the clamp meter, so there is no fuse needed?
Correct. The fuses in multimeters are
only on the amps ranges.
The other ranges have a very high resistance (eg. 10 MOhm) so not enough current can flow to make a fuse useful.
why are the chinese meters not good for mains work?
The answer to that question is very long and hardly anybody is qualified to answer it fully because the standards are only available to people who pay for them.
Most of the fuss about those meters is because they print false CAT ratings on the front. The CAT ratings printed on them
might be true on the voltage ranges but CAT ratings are supposed to apply to
all ranges, not just the voltage.
eg. Many of them say CAT III 100V on the front but when you open them up the fuses will say "250V".
Short version: If you're at home and you double-triple-check you're on a current range before probing then you're probably OK.
nb. you shouldn't be using probes to measuring current on mains devices - use a clamp for that.
wow, the Aneng meters are so cheap. Which is the "best" they offer, there is something better than the 860B+?
The 860B+ is near the top and plenty good enough for most things. You can get more digits if you want but it's not very useful/essential. Remember that most electronic components and power supplies are only 5 or 10 percent accurate.
The ANENG 870 is the next step up.
I am not sure what I need measure mAmps, can you tell me maybe an example?
LEDs are measured in mA.
If you want to know the consumption of a gadget powered by AA/AAA/9V batteries, that will be in mA (or maybe even uA!).
You mentioned "auto" work. Cars are where current clamps really shine. You just clamp it around a wire and read it. Even connecting a meter to a car using probes is a pain in the ass.
Bottom line: Only you know what you want the meter for and
one meter is never enough. Sometimes you need two meters at once (eg. for calculating power)
