Which could be equally said for modern mid-range and high-end scopes.
But it doesn't make current bottom-of-the-barrel scopes any more "mid-range". They still are what they are, the cheapest (reasonable) scopes money can buy.
Indeed,but they are better in so many ways than the things Tektronix & HP tried to foist on us in the dawn of the DSO era.
Yes, but again, this is due to normal technical progress and cost savings through high integration and cheap labor, not because the modern variant of a low-cost scope is inherently the better product (it is only 'better' because of the technical progress, after all HP & Tek had to work with the technology that was available back then). I'd even go as far as to say that inherently, these old Teks and HPs were the better products, because they offered better reliability and maturity as well as support. But then, hardly any of the early DSOs were classed (or priced) as entry-level scopes.
When most Oscilloscopes were purchased by organisations rather than individuals,the "Entry level" would have been that for small Radio/TV service shops,where something similar in performance to the BWD, or the Telequipment S31would have been (just) adequate.
The next level up would be that of Unis & Tech Schools.
Up from that would have been large Communications & Broadcasting organisations,which went from Tek 545s & the like,up through Tek 7000 series,to the last generation of Tek & HP Analogs. (mid level?)
In many cases,it wasn't the wider bandwidth which was important,so much as better triggering,Delayed timebases & so on.
In the late 1980s/early'90s,most people in this type of work were quite familiar with digital based equipment (for the youngsters reading--yes,there was digital equipment before microprocessors).
Perhaps for that reason,we expected more from the early DSOs we were offered,without considering that the design of such instruments was a lot more difficult than,say that of a digital video device which only had to operate 0-5MHz.
Alas,we were disappointed---the early DSOs were incapable of performing standard video tests,due to the large reduction in sample rate at PAL field rate frequency.
They were,for our purposes,useless pretty boxes,so we had no way to measure their reliability or support.
Modern DSOs could,in the main perform such tests,which although analog TV is gone,have their equivalents in other fields.
