Hi
I recently bought a EMI test receiver HP 85422E at an auction.
I have tested it, directing a single frequency into the RF input.
The gain is spot on, at most 0.5dB off. But the frequency is wrong.
If I enter 50MHz, I get 20MHz peak. If I then add 100MHz, it only increased the peak by 73MHz. It's consistent, every time I increase by 100MHz, only 73MHz is seen (generator has been checked on another spectrum analyzer)
I guess it works by sweeping a local oscillator, and generating an IF frequency.
What could be wrong?
Regards
Klaus
