Author Topic: Unusual LCD failure TDS3054  (Read 1667 times)
Offline JwallingTopic starter
  • This is work?
« on: February 11, 2018, 03:27:34 pm »
I don't think I've ever seen an LCD that fails with a vertical or horizontal line that didn't extend completely from side to side (or top to bottom)
Something new everyday...
Jay
System error. Strike any user to continue.
Offline nctnico
Re: Unusual LCD failure TDS3054
« Reply #1 on: February 11, 2018, 03:44:25 pm »
This could be a problem in the internal circuitry of the oscilloscope and not the display because it seems to occur in the signal trace overlay area. I'd try a different LCD first!
  • This is work?
« Reply #2 on: February 11, 2018, 03:55:39 pm »
Oh, I did! The replacement is fine.
Jay
Offline nctnico
« Reply #3 on: February 11, 2018, 04:00:52 pm »
Well then it certainly is an odd failure! Perhaps one of the traces on the glass itself got interrupted. I have seen localised defects in LCD screen though.
The following users thanked this post: Jwalling
  • This is work?
« Reply #4 on: February 11, 2018, 04:16:09 pm »
That would make perfect sense if the driver chip was on the bottom! Good call. I'd dissect it if I weren't going to use it as a test display...
I wonder how it could happen though; there's a protective anti-glare glass that covers the LCD.  :-//
Jay
Offline voltsandjolts
« Reply #5 on: February 11, 2018, 04:34:32 pm »
Where did you get the replacement LCD, from Tek?
  • This is work?
« Reply #6 on: February 11, 2018, 04:37:17 pm »
If I had, my wallet would probably be $500 lighter, assuming that they're not obsolete. ;)
I bought a couple of spares off eBay a year or two ago.
Jay
« Reply #7 on: February 11, 2018, 04:39:41 pm »
Hah, nice, wise move!
