CM82C
Test Parameters
DC current: 6A / 60A / 100A 0.001A / 0.01A / 0.1A ± ( 3.0% + 5 counts )
DC current ( uA ): 0 - 200uA 0.1uA ± ( 0.8% + 5 counts )
AC current: 6A / 60A / 100A 0.001A / 0.01A / 0.1A ± ( 2.5% + 5 counts )
DC voltage: 6V / 60V / 600V 0.001V / 0.01V / 0.1V ± ( 1.0% + 3 counts )
AC voltage: 6V / 60V / 600V 0.001V / 0.01V / 0.1V ± ( 1.0% + 3 counts )
Resistance: 600 / 6k / 60k / 600k / 6M ohm 0.1 / 0.001K / 0.01K / 0.1K / 0.001M ohm ± ( 1.0% + 3 counts ) 60Mohm 0.01Mohm ± ( 1.2% + 20 counts )
Capacitance: 600uF / 6000uF 0.1uF / 1uF ± ( 4.0% + 3 counts )
Frequency: 60Hz / 1000Hz 0.1Hz / 1Hz ± ( 1.0% + 5 counts )
Frequency ( by jaws ): 60Hz / 1000Hz 0.1Hz / 1Hz ± ( 1.0% + 5 counts )
Low impedance LOZ: Max 600V Resolution 0.1V
Buzzer: If the resistance is less than 30Ω, the continuity beeper sounds
Temperature: -20°C - 500°C 1°C / 2°F ( 2.0% + 2 counts )
Jaw capacity: 20mm
Power: 1.5V ( AAA ) x 2 ( not included )
Conform to the IEC-61010-1, IEC-61010-2-030, IEC-61010-2-032, IEC-61010-2-033 standards
Over-voltage protection class CAT III 300V, CAT II 600V, pollution degree II
UT210E
SPECIFICATION
Alternate Current 2A/20A/100A ±(2.5%+5)
Direct Current 2A/20A/100A ±(2.5%+3)
Alternate Voltage 2V/20V/200V/600V ±(1%+3)
Direct Voltage ±(0.7%+3)
Resistance 200Ω/2kΩ/20kΩ/200kΩ/2MΩ/20MΩ ±(1%+2)
Capacity 2nF/20nF/200nF/2μF/20μF/200μF/2mF/20mF ±(4%+5)
So the low current range is slightly worse accuracy (+0.5%), but has much wider range (0-6A). AC current and voltage have the same stated accuracy.
Not sure what you mean by range button, UT210E doesn't have it right? But this thing does not have manual ranges, so auto range which is good right.
Its cheaper on Aliexpress as well:
https://www.aliexpress.com/item/32962090990.htmlAre ACM91 and CM82C the same thing?
Review of ACM91:
https://lygte-info.dk/review/DMMBSide%20ACM91%20UK.htmlACM91:
https://www.aliexpress.com/item/1970498378.htmlCan get it in black, blue, or off-white:
https://www.aliexpress.com/item/1349685186.html
