Has anyone on here been successful with the USB Interface of the Uni-T UT8803?
For me, it seems to install a generic "Universal Test and Measurement" driver and will not allow the driver suggested by the UTI-T programmer's manual. After a lot of screwing around, I could NOT see my Siglent USB gear and went back to an older restore point to fix that.
By "see" i mean in the Keysight Connection Expert software that easily sees all my USB and GPIB gear.
I liked the 8803N because of the large display and also as a side of trying to use it as an A/D converter, more or less, its limited resolution is more than fine for what I attempted to use it for. For now, it is basically replacing a Fluke 37, which although cool, is just too old to be of much use (I was just using it as a Variac output monitor on the bench). The UNI-T will now assume that role but with a much nicer display. It would be nice to be able to get data from it through the USB port, but not necessary as I use an Agilent 34401 for that.
