The badcaps forums might have more info on specific brands, I just stick with Nichicon, Rubycon, Panasonic, United Chrmicon, etc so I don't have experience with the less known brands.
I would advise checking data sheets of the caps you remove and make a list that includes impedance/ESR and ripple rating of each cap and make sure your replacement caps meet or exceed those ratings (lower impedance/ESR and higher ripple current rating)
Also, check the pitch (distance between the legs) and height/width too, to make sure the new ones will fit...
