Author Topic: Transistor Tester Windows PC Software  (Read 2441 times)
Offline MesstechnikerTopic starter
« on: October 19, 2018, 12:10:54 pm »
Hi Transistor Tester community,
I am pleased to announce a piece of PC software for the infamous Transistor Tester. Its home is here:
https://www.mikrocontroller.net/svnbrowser/transistortester/Software/Messtechniker/
You will need a Transistor Tester (TT) running firmware v1.33m or higher with UART input and output enabled and an UART to USB converter. Prolific, CP2102 or FTDI FT232RL, for example. More information in the help file.
This software is not intended to replace a TT's display. Rather it is intended to facilitate matching of resistors as well as documenting the measurements. Piccy enclosed.
If the comments are not too harsh, a version for capacitors will be forthcoming soon.
Anyway have fun.
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
The following users thanked this post: oPossum, BravoV, madires, TheBay, 001, CatalinaWOW, indman, elecdonia, Jacon, v11
Offline CatalinaWOW
Re: Transistor Tester Windows PC Software
« Reply #1 on: October 19, 2018, 12:35:26 pm »
I like it.  Good idea.
Offline madires
  • A qualified hobbyist ;)
« Reply #2 on: October 19, 2018, 12:52:47 pm »
And don't forget to enable UI_SERIAL_COMMANDS also ;)
The following users thanked this post: 001
« Reply #3 on: October 26, 2018, 07:30:00 am »
The capacitor version of this prog is available now.
See link in first post.
The following users thanked this post: 001, indman, Jacon
Offline Kalvin
  • Embedded SW/HW.
« Reply #4 on: October 26, 2018, 07:46:13 am »
If one can download the new firmware from PC into the tester "as needed", one can extend and use the existing tester hardware as multipurpose testing device with many new capabilities without memory limitations: Just download a new firmware which will implement the required functionality.
The following users thanked this post: v11
Offline 001
  • Country: aq
« Reply #5 on: October 26, 2018, 07:50:14 am »
awesome app :-+
« Reply #6 on: November 01, 2018, 08:43:49 am »
And the next one has made it into the SVN. Link above.
BJT hFE for the transistor tester is there facilitating easy hFE matching of transistors.
Have fun.
The following users thanked this post: indman, Jacon, v11
« Reply #7 on: November 06, 2018, 07:07:04 am »
JFET IDSS for the transistor tester is there facilitating easy IDSS matching of JFETs.
This is the last one of this series :palm:.
If any tt firmware updates :scared: force me to update these proggies too - simply watch this space.  :popcorn:
Have fun.
The following users thanked this post: CatalinaWOW, indman, Jacon
Offline v11
« Reply #8 on: November 06, 2018, 09:01:55 pm »
@  Messtechniker
Thanks for your work.
You are a genius. ;)
BR.
