Through some fat fingering on ebay, I ended up with more of these than intended.
It looks like the 3468 is from 82, the second one down is from 83 and the bottom one is from 90 or so.
They all self test OK and seem reasonable, the only issue is that the 3478s have horrible measurement of 2-wire ohms. 3-4 ohms high, however in 4 wire mode they are spot on. Hmm... Perhaps the mechanical front/back terminal switch is cruddy? It would explain why the older 3468 with no back terminals seems to have better 2-wire sensing.
They all have calibration stickers so were part of a program at some point, but no papers, am I hurting the resale value at all if I break those calibration stickers to do something about the 3V ram batteries?
I was thinking of keeping one and then doing a supercap/battery mod to the others and selling them, do you think there is interest in supercap modded 3478a's on the resale market? By which I mean adding a 1F 5.5V supercap to the SRAM in addition to a socketed lithium cell, so you can just replace the battery without issue and use standard lithium coin cells.
Rigging up something with an IC clip to read the current RAM calibration values for hard storage (on a printed piece of paper paped inside the chasis if nothing else) is also something I'd like to do.
Something pretty cool I noticed about the 3468a is that it has a 'talk only' mode, where there is a dip switch you set on the back and it just spits out all its data on the HP-IL port on the back without waiting for any commands, which is a simple bit-bangable serial protocol. perhaps I can give it a nice VFD display via that route just displaying what it spits out and using the front panel for controls still. If only HP-IL cables didn't cost almost as much as the multimeters do i'd be experimenting with it by now....
John
