All right, time to lose signal again :)
Ph = 4, D = 550757, GL = 0, LOS = 3, ST = 40152, AF = 37, RT = 120341
Ph = 3, D = 550741, GL = 0, LOS = 3, ST = 40153, AF = 37, RT = 120342
Ph = 3, D = 550724, GL = 0, LOS = 3, ST = 40154, AF = 37, RT = 120343
Ph = 4, D = 550708, GL = 0, LOS = 3, ST = 40155, AF = 37, RT = 120344
Ph = 1, D = 550704, GL = 0, LOS = 3, ST = 40156, AF = 37, RT = 120345
Ph = 1, D = 550712, GL = 0, LOS = 3, ST = 40157, AF = 37, RT = 120346
Ph = 1, D = 550720, GL = 0, LOS = 3, ST = 40158, AF = 37, RT = 120347
Ph = 0, D = 550728, GL = 0, LOS = 3, ST = 40159, AF = 37, RT = 120348
Ph = -10000003, D = 550745, GL = 0, LOS = 3, ST = 40160, AF = 37, RT = 120349
Ph = -10000003, D = 550761, GL = 0, LOS = 3, ST = 40161, AF = 37, RT = 120350
Ph = -10000003, D = 550757, GL = 0, LOS = 3, ST = 40162, AF = 37, RT = 120351
Ph = -10000003, D = 550753, GL = 1, LOS = 3, ST = 40163, AF = 37, RT = 120352
Ph = -10000007, D = 550753, GL = 1, LOS = 4, ST = 0, AF = 37, sK = 0.00000, RT = 120353
Ph = -10000007, D = 550653, GL = 1, LOS = 4, ST = 1, AF = 37, RT = 120354
Ph = -10000007, D = 550653, GL = 1, LOS = 4, ST = 2, AF = 37, RT = 120355
Ph = -10000006, D = 550653, GL = 1, LOS = 4, ST = 3, AF = 37, RT = 120356
Ph = -10000002, D = 550653, GL = 0, LOS = 4, ST = 4, AF = 37, RT = 120357
Ph = -10000002, D = 425986, GL = 0, LOS = 2, ST = 0, AF = 37, RT = 120358
Meh. I won't be able to get a stable 24h+ of tracking without an outdoor antenna like this.
It's now flapping between the tracking and no-tracking states, so clearly the signal reception quality has degraded.
Well, at least I'm gonna leave it like this till morning and see if the lockup issue repeats.
I don't like the algorithm of what it does on signal loss. The output frequency changes quite abruptly when that happens. I don't have the numbers, but I see it on the scope: I'd estimate it at tens of Hz difference at least. Once it starts tracking again, it gets to sub-Hz difference against the TinySA cal output almost instantly. Apparently it simply stops applying the tuning voltage to the OCXO when the GNSS signal is lost, whereas I think the proper thing to do would be to retain the last known good voltage instead to at least let it run at a good enough frequency until the GNSS signal can be received again. I think that's a software flaw.
