First of all: - Thank you very much to everyone who has made this possible
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
The short version:
Last night I upgraded my TLA7AA2 from 120MHz state / 32M depth to 450MHz state / 32M depth. Today I upgraded my TLA7AA4 from 450MHz state / 8M depth to 450MHz state / 32M depth.
Terrific, worked as advertised, what more can you want?
Now the longer version:
When upgrading the TLA7AA2 I did everything absolutely exactly as in KK's post. All upper-case where he had it, and I included those silly Set/Save Parameter and Code: [Select] lines, etc. And, as I said, it all worked perfectly. But come this morning and those 'useless' lines were still annoying my subconcious, so I decided to have a quick look through the TLA7AAx firmware for any strings that looked like they might be associated. The bottom line is that there is a lot of stuff to look through, and I haven't yet made any connections, but in my perusals I noticed that there were virtually no all-upper-case symbols/table-entries etc. The password is there with its mixed case, but that was it. So I decided to try upgrading the second module with just lower-case command entries, and to also only enter the values that needed to be updated. In this case, the only change that needed to be made to the module was to increase the sample depth to 32M, so after establishing communication (remotely) using the Talker/Listener app, all I entered was
syst:pass:inst:pass "PitBull5.0.002"
syst:conf:depth 33554432
syst:pass:inst:upd 1404025200
and that was it.
So now I have 204 channels of nice high-speed capture. I hope I don't need it all to fix this $@#&*! Intel 8039 in my 3468A
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
I think there's an option for Ida Pro to look at Wind River stuff (can anyone confirm?) It might be interesting to have a bit of a dig through the code. And, of course, I could have the TLA get all incestuous with itself and capture what the 68360 is doing...
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
Ahhh...I just noticed an earlier post by dxl
I dissassembled the Firmware in 2009 to upgrade the Module.
@dxl - Did you use Ida, or some other 68000 dis-assembler? How far did you get into it?
Sailor
