Author Topic: Suggestion needed regarding differential scope probe  (Read 2004 times)
Offline SHARANYATopic starter
  • Country: in
« on: May 26, 2018, 03:52:21 pm »
Hi all
I am currently working on a project where it is needed to attach my scope probes to 220v AC(to watch Triac angle firing).Previously i was planning to buy a Pintek-DP25 & called my supplier.He told me to buy GWInstek GDP-025 instead of the Pintek.I am unable to find any kind of review/usage video regarding GDP-025 on the Net.Is this scope probe any good?Also,I have a rigol DS1102E scope.Can I attach the GDP-025 to my scope?
Offline Kean
    • Kean Electronics
Re: Suggestion needed regarding differential scope probe
« Reply #1 on: May 26, 2018, 04:48:12 pm »
As far as I know, the GWInstek GDP-025 and Pintek DP-25 are the same.  A quick search shows that seems to be the feeling of others too - e.g. see https://www.eevblog.com/forum/testgear/high-voltage-probes-for-rectfied-220v/msg374643/#msg374643
Further down in that topic is some interesting info about Pintek.
I have the Pintek DP-25, and in fact have been using it this evening to probe a high voltage ultrasonic driver.  I got it a few years back from https://www.globalmediapro.com/ and it was a lot cheaper than the other local suppliers I looked at, but that will depend on shipping to your location.  Some websites show the DP-25 is discontinued (e.g RS), but that is likely just because *they* no longer stock it.
If I was buying a new one today, I'd most likely get one with higher bandwith.  e.g the HVP70 from Dave https://www.eevblog.com/product/hvp70/ which seems pretty good.  But to be honest, I use it so rarely I probably couldn't justify it.
Offline PA4TIM
« Reply #2 on: May 26, 2018, 04:54:33 pm »
I have this one. https://www.picotech.com/accessories/high-voltage-active-differential-probes/25-mhz-1400-v-differential-probe
I think there is a lot of relabeling going on.  My Pico looks identical to the Fluke o fa friend.
Offline nctnico
« Reply #3 on: May 26, 2018, 05:08:11 pm »
Hi all
I'd get the differential probes from MicSig. They are cheaper, have more bandwidth and according to my testing have a flatter frequency response.
More info in this thread:
https://www.eevblog.com/forum/testgear/new-low-cost-($170)-100mhz-differential-scope-probe-from-micsig/msg1254420/#msg1254420
The following users thanked this post: Kean
Offline BillB
« Reply #4 on: May 26, 2018, 05:44:31 pm »
+1 for the MicSig.  With a $140 street price, they probably offer the best bang/buck.
  • Country: in
« Reply #5 on: May 26, 2018, 06:12:24 pm »
Although the MicSig probe is cheap,but in India,we have to pay a huge charge for individual customs clearance.That's why I was going for the GWInstek GDP-025 probe because the supplier directly imports & deals with the customs.
