Author Topic: Tips and Tricks: R&S RTB2000/RTM3000/RTA4000  (Read 8570 times)
Offline Rich@RohdeScopesUSATopic starter
Re: Tips and Tricks: R&S RTB2000/RTM3000/RTA4000
« Reply #25 on: August 15, 2019, 11:37:02 pm »
Another super cool one.  You can "pull out" menus so you have quick access to them.  Open the menu you want, grab it with your finger (or mouse) and slowly slide it to the left.  When you see the blue arrows you can pop it out in to the display.   You can then make quick changes.  You can also add multiple different quick access menus, move them around the display, etc. To delete them, just hit the gear and choose what ones you want to delete.
-Rich
« Last Edit: August 16, 2019, 04:31:02 pm by Rich@RohdeScopesUSA »
« Reply #26 on: August 15, 2019, 11:38:15 pm »
Does the gif above work for anyone?
-Rich
Online nctnico
« Reply #27 on: August 15, 2019, 11:39:12 pm »
Not for me.
The following users thanked this post: hwj-d, Rich@RohdeScopesUSA
Online jjoonathan
« Reply #28 on: August 16, 2019, 12:30:14 am »
I couldn't get the forum upload for gifs to work either. Same symptoms. I've been uploading to gfycat.com and then hotlinking to the thumbnail from (User Heiroglyph > Profile). Presumably there's a bandwidth limit but I haven't hit it yet.
The following users thanked this post: Rich@RohdeScopesUSA
Offline EEVblog
« Reply #29 on: August 16, 2019, 02:16:02 am »
I'm guessing the new plugin doesn't support animated GIF's?  :-//
« Reply #30 on: August 16, 2019, 03:39:59 pm »
Thanks for the tip.  Hopefully what I did above works now (you have to click the image to see the animation).
-Rich
Offline Kean
    • Kean Electronics
« Reply #31 on: August 16, 2019, 03:59:54 pm »
Yup, thanks.  I'll have to try that - it looks really useful.
« Reply #32 on: August 16, 2019, 04:15:48 pm »
One more quick one - you can adjust window size easily using the arrows on the left side of the graticule.  This works in zoom mode, FFT, serial decode, etc.  No need to have a fixed window ratio.
Click on the image to see the animated version if the gif doesn't work for you.
-Rich
« Reply #33 on: August 16, 2019, 04:31:59 pm »
Looks like gifs are working again?   :-+
I've updated the posts - let me know if you all can't see them directly in the posts now.
-Rich
The following users thanked this post: Kean
Offline genghisnico13
  • Country: cl
« Reply #34 on: August 16, 2019, 05:09:32 pm »
The last one (the one about resizing) is perfect, good size and it works on desktop and mobile.
The one about quick access works, but is big on the desktop.
« Reply #35 on: August 16, 2019, 09:07:11 pm »
OneTouch is pretty cool too, especially if you're doing documentation.  Basically allows you to configure the "camera" button to not only save a screenshot, but also your setup, waveform file, references, event tables and even statistics, all in to a zip file on your thumbdrive with one push.  You can choose what all you want to be saved.
-Rich
PS - I tried resizing this one so hopefully it is more viewable across different platforms.  Let me know.
The following users thanked this post: Kean, hwj-d, maginnovision
Offline hwj-d
  • save the children - chase the cabal
« Reply #36 on: August 16, 2019, 10:02:19 pm »
Horizontal resolution is fixed! This can't work.
(Think of smartphones.)
« Last Edit: August 16, 2019, 10:05:25 pm by hwj-d »
Offline zitoune
  • Country: sg
« Reply #37 on: August 02, 2020, 04:23:23 am »
Hi Rich,
Thank you for all those tricks; they are very useful!
I got a RTM for a couple of days now and love it. I was wondering how you can display the decoded values (say from an I2C bus) vertically - meaning the HEX values are not displayed like all the screenshots we usually see but rather like what's visible in that R&S image: https://cdn.rohde-schwarz.com/pws/powerslave/504580/18/import5a214aee0d0d9.jpg
Thanks!
« Last Edit: August 02, 2020, 06:41:25 am by zitoune »
Offline Hydron
« Reply #38 on: August 02, 2020, 01:09:23 pm »
Use the V/div control to expand the decode vertically, then see if it'll do it.
The following users thanked this post: zitoune
Offline egonotto
« Reply #39 on: August 02, 2020, 02:02:24 pm »
Hello,
in the picture are not the decoded value in the table but the relative time of the single segments.
Best regards
egonotto
Offline zitoune
  • Country: sg
« Reply #40 on: August 02, 2020, 02:26:51 pm »
Thank you - indeed changing the V/div scale does work. Very handy, you can see more decoded values on the screen!
Offline zitoune
  • Country: sg
« Reply #41 on: August 02, 2020, 02:27:28 pm »
Hello,
Best regards
egonotto
Yes indeed, I was looking at the decoded values on the top part of the screen.
Offline egonotto
« Reply #42 on: August 02, 2020, 03:16:03 pm »
Hello,
what I can get is shown in the two pictures.
Best regards
egonotto
Offline zitoune
  • Country: sg
« Reply #43 on: August 20, 2020, 03:46:13 am »
Yes this is exactly what I was looking for and it is even more handy when decoding long words like in the attached screenshot (24bits I2S protocol).
Thanks.
