Tap on clock opens time and date setup.
Tap on interface icon opens interface short information window (e.g. this is helpful if you need the IP address quickly).
Tap on gear wheel opens interface menu (this is more if you need to update your USB/Ethernet settings - it gives you quick access to that menu).
Tap on information window opens numeric keypad.
Tap on waveform marker to select a waveform. Every marker is moveable.
You can name your device:
SCPI: syst:name “ViliWonka”
If you tap on menu item it will increment the selection in pull down menu.
-Rich
