Also beware when charging batteries. Always use a series diode (for DP832 it is specified in the manuals) and a fuse.
For example when charging a car battery, at a mains power surge, or at an accidental reset, or if the power supply become defective, then your battery will become the source and may damage the power supply. And if the battery is big enough, a short circuit in the power supply can easily start a fire.
