Author Topic: The unobtanium connector of Solartron 7061, what to do, please help ?  (Read 23461 times)
Offline lowimpedance
  • Watts in an ohm?
I believe one member have said that the size is M15, that means the hole is 12mm in diameter, can it be confirmed ? Because if we change the connectors, at least not drill or affect the panel.
 DC1MC
Okay the picture below is of one of these connectors salvaged from a defunct Solartron. The measured diameter of the threaded section is for a 15mm hole. The front outer ring of the socket is 19mm.
Cable diameter on plug is 7mm OD. and the cable is shielded 4 core with each core having that 'PTFE' feel !.
« Last Edit: May 11, 2018, 01:21:37 am by lowimpedance »
The following users thanked this post: DC1MC
Offline DC1MCTopic starter
 DC1MC
Now it's much clear, many thanks.
 DC1MC
Offline tggzzz
but what to get for some nice shielded dual conductor flexible cable for the main set of 2 wire test leads ?
I'm going to try this one : https://www.ebay.ca/itm/NOS-PTFE-silver-plated-cable-wire-20awg-4c-Shielded-3meter-Speaker/253173432482?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Will use it for 2 and 4 wires test leads (as recommended in the manual).
It appears that the outer insulation jacket is PTFE but it does not state what the individual wire insulation is. That is sufficient to prevent external chemical/UV/etc damage to the cable.
However, I've seen quite a few cables where the individual wire insulation is something else, e.g. PVC. That is, if you are fussy, less good with respect to insulation and leakage between wires. Whether that matter is a separate issue, of course.
Well, got the Chinglish reply at the question if the individual wires are also in PTFE isolation. direct quote:
"Neue Nachricht von: ayumitubes Top Rated Seller(8,365Green Star)
HI Sir :)
Yes, all PTFE    Thank you
Best Regards
Alex
So this is this  ;D,
DC1MC
Now that the cable is done, what are recommending on the business end, hi-quality bananas,  tips, grabbers, all ideas, advices and sources welcome.
 Cheers,
 DC1MC
Offline tggzzz
HI Sir :)
Best Regards
Alex
So this is this  ;D,
DC1MC
Fomdle the wires when you get them :)
Offline tggzzz
ISTR at the last https://maker-faire.de/hannover/ the PTB's hp3458 had cables with small gold plated hollow banana plugs. Not sure of the attachment mechanism to the wires, but I suspect solder. Stackable connectors are a convenience.
Take your DMM and check its calibration :)
Also take a camera to photograph geek porn such as Josephson Junctions,
https://www.eevblog.com/forum/metrology/ptb-at-the-maker-faire-in-hannover/msg1267015/#msg1267015
Offline Kosmic
Search for "bfa banana plug" on ebay  :)
Offline Kosmic
On my side I think I will go with Pomona low EMF banana plug.
EDIT: error on my side, look like Pomona only make low EMF Spade https://www.pomonaelectronics.com/products/hardware/low-thermal-emf-spade-lug-gold-plated. So it will be regular copper / gold plated banana plug then
« Last Edit: May 11, 2018, 03:28:08 pm by Kosmic »
Come on dear German/EU forum members, really nobody wants some overpriced but hi-quality connectors for their Solartrons  :-\ to make the 10pcs quota from Andreas  :scared:?
Please don't for me to fudge other connectors, drill holes and crap in my 7071 !!!
 Waiting with hope,
 DC1Mc
Offline tggzzz
I'm waiting for a quote from Fischer UK. I emailed early in the week but no response. I re-asked the question with a different person on Friday afternoon. Unless I misheard him (which is all too possible), he said there was a £50 minimum order limit.
After I receive a quote (or get bored waiting!), we can all make a decision as to how to proceed - possibly via me, possibly via Andreas.
« Last Edit: May 12, 2018, 07:03:17 pm by tggzzz »
Offline Ero-Shan
 Waiting with hope,
 DC1Mc
Sorry. But that's just too expensive for my taste. That's about ten times what I paid for the instrument itself. :-[
Offline tggzzz
Welcome to voltnuttery :) Open your wallet.
Did you really only pay ~EUR5 for the instrument? A connector is, hopefully, ~EUR50 + post and packing.
Hmm Ero-Shan, where do you Leute  :P find these things, SA with 100EUR, 7,5 digits Solartorns with 5EUR, am I doing something wrong  :-// ?
 Cheers,
 DC1Mc
Offline Kosmic
To be fair, mine was cheap but also broken. It's my next repair project. It fail 0V test but overall kind of works  :)
Offline Neomys Sapiens
I'm in for one.
How is the procedure?
I'm in for one.
Well, I think we should let Andreas know how many we want and when we reach 10 send him the cash so he can order, in the mean time I'm looking for banana plugs will gold plating, actually the are not so expensive, too bad that Farnell doesn't serve private customers in Germany, they really have a nice selection.
 Cheers,
 DC1MC
Hopefully the worst thing will be some incapacitated capacitors  ;D or just some calibration related stuff.
 Good luck and let us know how it went,
 DC1MC
Offline The Soulman
  • The sky is the limit!
I'm in for one.
 Cheers,
 DC1MC
I'm happy with these:
https://www.reichelt.nl/Stekker-koppelingen/LAS-30-AU-RT/3/index.html?ACTION=3&LA=2&ARTICLE=130856&GROUPID=5625&artnr=LAS+30+AU+RT&trstct=pol_6
However I'm not a genuine voltnut.  :)
 DC1MC
MC/Staeubli and nothing else! They will sell, but they have a minimum order value. I need some stuff from them too, so we could arrange something.
Offline tggzzz
I'm in for one.
 Cheers,
 DC1MC
I'm concerned about that style having rotating baskets/lanterns. That means there is only a low-pressure contact, and I don't understand what that might do when measuring uV.
However, I'm only a wannabe voltnut - or rather a wannaNOTbe voltnut :)
Offline tggzzz
I'm in for one.
I'll be in a position to make a statement by the end of next week.
If we are all being nice to each other, I don't mind adding things to a Farnell order and then forwarding them.
Offline tggzzz
« Last Edit: May 13, 2018, 08:34:00 am by DC1MC »
Offline capt bullshot
The PKI are fine, the rest I don't like for various reasons.
IMO the BUELA are just crap, no matter how much gold is applied. The test leads are okayish, but not as nice as the proper MC ones (the plugs are too bulky and loose).
