I believe one member have said that the size is M15, that means the hole is 12mm in diameter, can it be confirmed ? Because if we change the connectors, at least not drill or affect the panel. DC1MC
Quote from: DC1MC on May 08, 2018, 06:26:31 pmI believe one member have said that the size is M15, that means the hole is 12mm in diameter, can it be confirmed ? Because if we change the connectors, at least not drill or affect the panel. DC1MCOkay the picture below is of one of these connectors salvaged from a defunct Solartron. The measured diameter of the threaded section is for a 15mm hole. The front outer ring of the socket is 19mm.Cable diameter on plug is 7mm OD. and the cable is shielded 4 core with each core having that 'PTFE' feel !.
Quote from: DC1MC on May 10, 2018, 07:12:22 pmbut what to get for some nice shielded dual conductor flexible cable for the main set of 2 wire test leads ?I'm going to try this one : https://www.ebay.ca/itm/NOS-PTFE-silver-plated-cable-wire-20awg-4c-Shielded-3meter-Speaker/253173432482?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649Will use it for 2 and 4 wires test leads (as recommended in the manual).
Quote from: Kosmic on May 10, 2018, 11:05:58 pmQuote from: DC1MC on May 10, 2018, 07:12:22 pmbut what to get for some nice shielded dual conductor flexible cable for the main set of 2 wire test leads ?I'm going to try this one : https://www.ebay.ca/itm/NOS-PTFE-silver-plated-cable-wire-20awg-4c-Shielded-3meter-Speaker/253173432482?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649Will use it for 2 and 4 wires test leads (as recommended in the manual).It appears that the outer insulation jacket is PTFE but it does not state what the individual wire insulation is. That is sufficient to prevent external chemical/UV/etc damage to the cable.However, I've seen quite a few cables where the individual wire insulation is something else, e.g. PVC. That is, if you are fussy, less good with respect to insulation and leakage between wires. Whether that matter is a separate issue, of course.
"Neue Nachricht von: ayumitubes Top Rated Seller(8,365Green Star)HI Sir Yes, all PTFE Thank youBest RegardsAlex
Well, got the Chinglish reply at the question if the individual wires are also in PTFE isolation. direct quote:Quote"Neue Nachricht von: ayumitubes Top Rated Seller(8,365Green Star)HI Sir Yes, all PTFE Thank youBest RegardsAlex"So this is this ,DC1MC
Now that the cable is done, what are recommending on the business end, hi-quality bananas, tips, grabbers, all ideas, advices and sources welcome.
the PTB's hp3458 had cables with small gold plated hollow banana plugs. Not sure of the attachment mechanism to the wires, but I suspect solder. Stackable connectors are a convenience.
Come on dear German/EU forum members, really nobody wants some overpriced but hi-quality connectors for their Solartrons to make the 10pcs quota from Andreas ?
Come on dear German/EU forum members, really nobody wants some overpriced but hi-quality connectors for their Solartrons to make the 10pcs quota from Andreas ?Please don't for me to fudge other connectors, drill holes and crap in my 7071 !!! Waiting with hope, DC1Mc
Sorry. But that's just too expensive for my taste. That's about ten times what I paid for the instrument itself.
I'm in for one.How is the procedure?
To be fair, mine was cheap but also broken. It's my next repair project. It fail 0V test but overall kind of works
Quote from: Neomys Sapiens on May 12, 2018, 11:01:49 pmI'm in for one.How is the procedure?Well, I think we should let Andreas know how many we want and when we reach 10 send him the cash so he can order, in the mean time I'm looking for banana plugs will gold plating, actually the are not so expensive, too bad that Farnell doesn't serve private customers in Germany, they really have a nice selection. Cheers, DC1MC
Quote from: Kosmic on May 12, 2018, 10:53:09 pmTo be fair, mine was cheap but also broken. It's my next repair project. It fail 0V test but overall kind of works Hopefully the worst thing will be some incapacitated capacitors or just some calibration related stuff. Good luck and let us know how it went, DC1MC
Quote from: DC1MC on May 12, 2018, 11:26:40 pmQuote from: Neomys Sapiens on May 12, 2018, 11:01:49 pmI'm in for one.How is the procedure?Well, I think we should let Andreas know how many we want and when we reach 10 send him the cash so he can order, in the mean time I'm looking for banana plugs will gold plating, actually the are not so expensive, too bad that Farnell doesn't serve private customers in Germany, they really have a nice selection. Cheers, DC1MCI'm happy with these:https://www.reichelt.nl/Stekker-koppelingen/LAS-30-AU-RT/3/index.html?ACTION=3&LA=2&ARTICLE=130856&GROUPID=5625&artnr=LAS+30+AU+RT&trstct=pol_6However I'm not a genuine voltnut.
