Hello everybody, first of all, thanks everybody for the pictures, it seems that the mounting is not as bad as I was expecting it. actually is pretty simple to unsolder and replace the connectors.
I believe one member have said that the size is M15, that means the hole is 12mm in diameter, can it be confirmed ? Because if we change the connectors, at least not drill or affect the panel.
Now for the few forum members, is anybody else willing to call the Fischer, I'll take two connectors, one for a 2-wire lead and one for a 4-wire lead. Should we try to do a collective order ?
Or should we replace the connectors in a consistent way and invest the difference in hi-quality shielded test leads and Kelvin clips ?
Knowing my luck, after I'll change the connectors and invest in the test leads, somehow the market will be flooded with cheap or reasonably priced original test leads, if I'll keep the connectors, most likely I'll finish my reincarnation and not even see an original Solartron lead
But whatever the conclusion of the forum is, I will go with the crowd wisdom and do it as such, specking of which, what are some good quality shielded leads with and without Kelvin clips.
And what are the favorites for the new connectors, here I'm listing my finds as well:
https://www.ebay.de/itm/GX12-Luftfahrt-Rundstecker-Stecker-und-Buchse-Durchmesser-12mm/132576372856https://www.ebay.de/itm/LEMO-3-5-PIN-BREVETE-S-G-D-G-Circular-Push-Pull-Connector-FFA-3E-650-CLAC11/273030611729And for the Teflon or other plastic type original guy, I vote to pick up the least expensive compatible one, if one of bio-Germans will give a call to Fischer, just to get a price and availability, I'll be grateful, if not I'll try to do it, but they may close the phone
Waiting for your opinion,
DC1MC
