*Bump*
well, got myself a 7061 and, offcourse..., it came without the measuring connectors.
can't find the Fischer thing anywhere and am in doubt..
i also have a Philips LCR meter with the specific LEMO FGG.2B. 308. CLAD and think about converting this Solartron to those connectors. Thereby maintaining the original layout and idea and having 1 set of testleads to use on both meters.
other option is to convert it to something standard, as RS-online 209-5680 and so maintaining the original layout and idea.
or convert it to Pomona 3770.
anyway, i'll do either one of the above and get it running.
question here is, mine has the Scanner option 70612A, this also has some small 5 pins connectors.
but, what will fit in these ?
size is 8,5mm
i'll have 8 extra inputs to use :-)
