MadTux, my direct email is george@mrrace.com, appreciate your offer very much.
Mark, I could not get the +15 even close. After setting the 23 volt line, it was at almost 25 volts, I then was able to swing the 15 volt line from 14 to 16 volts, the control almost centered at +15.
Don't see how that could be the case, looking at the power supply diagram, but it really did happen. Maybe I just don't remember correctly what I did initially when I tried to adjust the various voltage controls!
I did look at power supply ripple, not a bit on the regulated side of any of the voltages. So the input capacitors of the power supply are still doing a good job. Actually, looks like a couple of the bigger ones have been changed out.
Boy you talk about being dumb! ME!!!!!!
Yesterday I was moving some parts around in my shop and knocked over the case top for one of the 8116's that I currently have apart. Inside of the top cover is a perfectly printed layout of ALL the CONTROLS ON THE MAIN BOARD! When I get a chance I will take some nice pictures of the two different layouts that I have apart, and post them here, just in case someone like me can't find them. They are both different from the service manual that I have, somewhere there must be some updates that include all the different version. Probably somewhere in a service shop in Germany, where these darn things were assembled.
Mark, in spite of the error message, the instrument seems to be working perfectly, although I have not methodically gone through all the many functions it will do. But output frequency and levels seem to be in the ball park, for the most part.
Had to work on some other equipment the past couple of days, so have not spent any more time with the problem child. But this coming week it looks like I will have a bit more bench time.
Thanks to all for all the suggestions and information, I will follow up on each where I can.
George
