The fan in my unit started making a slight annoying buzzing noise, so I opened it up to see if I could manipulate the fan to get rid of the noise (which I was able to).
While I had it open I noticed it had the Siglent signature rust on the edges of some of the metalwork. It was only slight and am sure it won't be a problem but does show poor attention to detail.
Its not a bad quality fan but there could be less air cooling circulation noise in this generator (which mainly comes from the box working like a speaker cabinet)
I don't know if it is calculated for worse case scenario when installed in a rack as it is, but for home lab use maybe a Sunon fan (HA60251V4-999 looks good) with some 3V drop resistor inline could suffice for safe cooling and about half the final audibility. Maybe Siglent can advise us here about which is the max CPU sink's temperature for long term reliability?
No (at least not yet) buzzing noise from mine generator's fan, i can hear a moderate air flux sound that maybe is one-tenth of the of DS1074Z's fan noise, so i can say i feel good with it.
What about the warranty sticker placed on the generator box ?
I guess we have to cut it to get access to instrument's fan and does not seem a smart move.
Anyway, talking about DC fans, i feel we have a very high unit to unit performance/quality variance, ie my original GW Instek scope's ADDA fan (60x60x25 too) is a piece of cra@p, dunno if it's a fake device or actually ADDA make crap, i wonder why GW Instek uses this crap for its instruments, i swapped it with a 60x60x15 Sunon Maglev with
surprisingly better result for 4 Euro 1 Pz street price.
GW Instek also made a mechanical design mistake putting the fan intake side too close to circuit metal shielding case (8-9mm) simply suffocating it, indeed the slimmer version i used leaves 5mm more air space and works waaay better.
Here Siglent seems to have done a much better job, at least with mine 2042X.
