Got a SDG2042X last week and today noticed something that doesn't seem right. I haven't tested all possible combinations of settings for this (only Linear vs Log seem to make a difference) but when generating a linear sweep, the sweep starts at the center frequency, goes up to the end frequency, jumps back to the start frequency and then goes back up to the center frequency (then starts over if trigger source is set to internal, or stays at center frequency if trigger source is manual). If I set the sweep type to log, the sweep starts at the start frequency and ends at the stop frequency like I was expecting. None of the other settings seem to have any affect on this behavior, including using CenterFreq/FreqSpan instead of StartFreq/StopFreq. I am testing by hooking the generator directly to my scope with a coax, generator set to 50Ohm Load and scope set to 50Ohm input. This is the first generator that I've owned that could do sweeps so maybe they all behave this way, but to me it seems like both Linear & Log sweep types should work like the Log sweep does. To make it easier to verify this behavior I set the sweep trigger source to manual (though it does the same if set to internal) and the generator outputs the center frequency when set to Linear, and the start frequency when set to Log, until I manually click the Trigger button to start the sweep. Probably not a big deal just didn't seem quite right to me. Or I just don't know how sweeps are supposed to work (which wouldn't surprise me).
SDG2042X
Hardware Version: 01-07-00-23-00
Software Version: 2.01.01.15R2 (latest to the best of my knowledge)
