Author Topic: The Siglent SDG2042X Thread  (Read 682717 times)
Offline Bad_Driver
Re: The Siglent SDG2042X Thread
« Reply #1825 on: July 18, 2024, 05:14:49 am »
Hi Bad_Driver,
Think you are the first to do this!  ;D
You did apply the 50uSec pe amphase, otherwise it sounds very “dull”
Kind regards,
Bram
I know, I know. In the meantime I built a much better Stereo Encoder
https://media.elv.com/file/2001_02_01_se100.pdf
and use a RF-generator for this kind of fun.
„Everything must be made as simple as possible. But not simpler.”
― Albert Einstein
Offline KungFuJosh
  • TEAS is real.
« Reply #1826 on: August 09, 2024, 02:06:48 am »
The screenshot button works!...poorly.
I saved a screenshot today holding down the store/recall button. It saves to the Local drive instead of the USB drive.
That's extra annoying, and there doesn't appear to be any way to change the settings for it. Yes, I also checked the latest manual.
To copy the .bmp file (which should be a .png file) you have to browse to the Local drive, adjust the file types that are visible, then select and copy the .bmp file, then browse to the USB drive, and paste the file. You might also need to change the visible file types again if you want to see what's actually on the USB drive. It's very clunky.
I hope they fix this. When a USB drive is inserted, screenshots should automatically save to the USB drive instead. In general, they should improve the file browsing on these.
Thanks,
Josh
The following users thanked this post: Performa01, tautech, Martin72
Offline KungFuJosh
  • TEAS is real.
« Reply #1827 on: August 09, 2024, 03:02:47 am »
I ran another test with the Reference Out connected directly to the Counter.
Then I took a screenshot. It displayed the confirmation.
Then I went through the tedious process of copying the screenshot from Local to USB.
Viewed it on my PC and this is what was captured:
I went through the whole process again and it captured properly:
« Last Edit: August 09, 2024, 03:07:11 am by KungFuJosh »
Offline tautech
« Reply #1828 on: August 10, 2024, 01:08:12 am »
Thanks,
Josh
Acknowledged by HQ and stated that improvements will come.
The following users thanked this post: bson, KungFuJosh
Offline KungFuJosh
  • TEAS is real.
« Reply #1829 on: August 10, 2024, 01:45:13 am »
Thank you!
Now convince them to add a web server. 😉😉
Offline tautech
« Reply #1830 on: August 10, 2024, 01:52:21 am »
Thank you!
Coming in SDG1000X Plus and already exists in $ $ SDG7000A.  :P
Offline KungFuJosh
  • TEAS is real.
« Reply #1831 on: August 10, 2024, 02:05:32 am »
Thank you!
I want it in my SDG2122X! 😭😭
The following users thanked this post: Wrenches of Death
Offline slavoy
« Reply #1832 on: August 16, 2024, 09:53:05 am »
All the buttons are constantly lit... During the LEDTest, there are no changes; the buttons stay lit. So, I guess I need to pack it up and send it for service?   :'(
I'm tempted to take it apart  >:D
Look at this. The generator sat for about a month waiting for repair. I turned it on yesterday and saw this. The button backlighting is working fine again. Honestly, I'm not particularly happy because it’s an intermittent issue. But at least it's working now.
The repair files from @tautech wouldn’t load from various USB drives. I’ve ordered another 10 low capacity ones from Aliexpress and am waiting for the shipment. Still want to try the repair procedure anyway and maybe disassembling the unit to check it out.
Offline neskor
  • Country: cs
« Reply #1833 on: October 20, 2024, 11:42:15 am »
Hi.
I tried to upgrade the firmware on my Siglent SDG2042X.
Original firmware was 2.01.01.23R3
Updated first to 23R8, then to 35R3B1 without problems.
But when I tried to update to 35R3B2 I got some error as not enough space on C:
I tried to power off/power on device and after that I'm getting just black screen.
Is there any solution for this situation?
Thank you in advance.
Offline JDubU
« Reply #1834 on: October 20, 2024, 12:18:10 pm »
Take a look at:
https://www.eevblog.com/forum/testgear/the-siglent-sdg2042x-thread/msg4969273/#msg4969273
and the following posts.
The problem is a file called SIGLENT.ADS that was not automatically deleted during a previous firmware upgrade.  It is supposed to be temporary and, if not deleted, prevents future firmware upgrades by taking up too much storage space.
Offline neskor
  • Country: cs
« Reply #1835 on: October 20, 2024, 12:36:12 pm »
I can't do telnet :(
My unit is bricked, doesn't want to boot. Only black screen on startup.
Probably I need recovery files from Siglent to put on micro SD and try to boot from SD card, but I don't have those files :(
Offline JDubU
« Reply #1836 on: October 20, 2024, 12:51:50 pm »
Tautech?
Offline neskor
  • Country: cs
« Reply #1837 on: October 20, 2024, 01:03:07 pm »
Now is 2AM in NZ, he is probably sleeping  :D
Offline tautech
« Reply #1838 on: October 20, 2024, 06:26:27 pm »
USB recovery should fix this.
Siglent EU HQ will have what you need.
info-eu@siglent.com
Offline neskor
  • Country: cs
« Reply #1839 on: October 21, 2024, 05:51:23 pm »
Finally received the files from US support, EU support didn't repsond at all.
Copy the files on root folder of 4GB USB thumb drive, formated as FAT32.
Power on the unit but nothing is happening. Waited for 10 min  :(
Doesn't boot at all.
Offline neskor
  • Country: cs
« Reply #1840 on: October 21, 2024, 08:34:39 pm »
I made it with micro SD card inside the unit.
Found it here:
The following users thanked this post: KeBeNe, 2N3055, famalex, Mortymore
