I have a problem:
If I use the internal trigger source when I sweep a signal, everything works flawlessly. But when I try to trigger from external source, the signal starts to disappear and it doesn't work as it should anymore. I tried 2 different external generators as a trigger source and the result was the same. Of course the external trigger signal is with the same amplitude and frequency as the internal one. Any ideas how to fix this? And yes, I tried the same scenario with my other Rigol DG1022Z generator and it works flawlessly with both internal and external trigger sources while sweeping. I only bought this SDG2042 because of the higher frequency capabilities, but now I'm starting to bitterly regret. Every function I need, simply doesn't work properly. I made a short video with english subtitles/closed captions, trying to demonstrate the problem. You can take a look, if interested. Thank you!
