Hello guys. Not sure if this issue was raised before, if so, sorry about duplicate. If not, can someone throw an opinion , please ?
Just acquired a "matching" pair of SDS1104X-E -- SDG 2042X specifically, for the Bode plot feature and the ease of hackability, didn't go for the higher end models, for this kind of equipment in general is like 50-100% pricier in this country than the advertised price by manufacturer. And obviously didn't want to wait 50 days for direct order from China ( but even if i did, the difference would be marginal, killer customs taxes, darn EU is so fckd up...).
Unlocked successfully the SDG to 120 MHz, works, but the signal level starts to drop from 80 MHz, falling to half at 120 MHz. I have the HW revision 02-xxxx, not the 05-xxxx, brand new, under warranty, etc., freshly imported through the Netherlands trade point. Not sure why it isn't the 05 version though.
I did verify the signal levels using different cables, one that should work up to the GHz ranges. Tested with the unlocked SDS and an older analog Hitachi scope. May not be mV accurate, but still the same proportianal decrease in signal level, from 80 to 120 MHz, the signal gradually drops to half.
Not sure how to proceed. Is this something eligible for Siglent support, or do you guys have any suggestion ? Maybe need to solder in or replace some components at output stage, if so, does anyone have some isntructions for ? It feels very much like a low pass filter , maybe a hardware bug in this model ?
Thanks in advance.
PS. great forum with great people all around. Practically i've made my choice on the purchase solely based on this forum and Dave's videos, the alternatives would have been models from Rigol, Hantek and Owon. Siglent had the best price-performance report (that includes the unlocking factor) and fastest shipment.
