Hi everybody,
I got a problem similar to the one here:
https://www.eevblog.com/forum/repair/help-fixing-siglent-sdg805/, but with an SDG2042X. At some day, it just stopped booting up further the logo screen.
I already saved the boot log ouput via UART but I don't really know what the error at the end is telling me exactly...
U-Boot SPL 2013.01.01-svn72327 (Nov 06 2019 - 11:19:35)
config ddr_pll_config()++
config ddr_pll_config()--
nand_init+++++
nand_init-----
Lcd_Init()++
SetUpLCD()++
SetUpLCD()--
len=522292, height=272, width=480
Logo from nandflash: base=0x81000000; end=0x8107f81f; end-base=0x7f81f; rwsize=0x7f820; r=0x0
Lcd_Init()--
U-Boot 2013.01.01-svn72327 (Nov 06 2019 - 11:19:35)
I2C: ready
DRAM: 128 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Using default environment
set_default_env::8123
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw
Hit any key to stop autoboot
mmc_send_cmd : timeout: No status update
Card did not respond to voltage select!
(Re)start USB...
USB0: lowlevel init failed
USB error: all controllers failed lowlevel init
Download Linux from USB to Nandflash...
** Bad device usb 0 **
Booting from nand ...
NAND read: device 0 offset 0x3080000, size 0x300000
3145728 bytes read: OK
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Linux-3.2.0-svn223263
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2812168 Bytes = 2.7 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 3.2.0-svn223263 (david@david-virtual-machine) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #42 Wed Nov 6 11:19:32 CST 2019
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: am335xevm
[ 0.000000] Ignoring tag cmdline (using the default kernel command line)
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=ubi0:rootfs ro ubi.mtd=7,2048 rootfstype=ubifs rootwait=1t ip=none
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 128MB = 128MB total
[ 0.000000] Memory: 123756k/123756k available, 7316k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xc8800000 - 0xff000000 ( 872 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0529364 (5253 kB)
[ 0.000000] .init : 0xc052a000 - 0xc056c000 ( 264 kB)
[ 0.000000] .data : 0xc056c000 - 0xc05bd350 ( 325 kB)
[ 0.000000] .bss : 0xc05bd374 - 0xc060103c ( 272 kB)
[ 0.000000] NR_IRQS:396
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER2 at 25000000 Hz
[ 0.000000] omap_dm_timer_switch_src: Switching to HW default clocksource(sys_clkin_ck) for timer1, this may impact timekeeping in low power state
[ 0.000000] OMAP clocksource: GPTIMER1 at 25000000 Hz
[ 0.000000] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 171798ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000212] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[ 0.057101] pid_max: default: 32768 minimum: 301
[ 0.057280] Mount-cache hash table entries: 512
[ 0.057669] CPU: Testing write buffer coherency: ok
[ 0.057746] ftrace: allocating 14556 entries in 43 pages
[ 0.109567] omap_hwmod: gfx: failed to hardreset
[ 0.125622] omap_hwmod: pruss: failed to hardreset
[ 0.126786] print_constraints: dummy:
[ 0.127072] NET: Registered protocol family 16
[ 0.129315] OMAP GPIO hardware version 0.1
[ 0.131577] am335x_evm_init()++
[ 0.131803] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.134029] am335x_evm_i2c_init()++
[ 0.134267] omap_i2c.1: alias fck already exists
[ 0.134471] am335x_evm_i2c_init()--
[ 0.134599] da8xx_panel_power_ctrl()++
[ 0.134638] back light switch = 1
[ 0.134660] da8xx_panel_power_ctrl()--
[ 0.134975] am335x_evm_init()--
[ 0.135278] omap2_mcspi.1: alias fck already exists
[ 0.135496] omap2_mcspi.2: alias fck already exists
[ 0.135765] edma.0: alias fck already exists
[ 0.135787] edma.0: alias fck already exists
[ 0.135806] edma.0: alias fck already exists
[ 0.152705] bio: create slab <bio-0> at 0
[ 0.154858] SCSI subsystem initialized
[ 0.156661] usbcore: registered new interface driver usbfs
[ 0.156986] usbcore: registered new interface driver hub
[ 0.157240] usbcore: registered new device driver usb
[ 0.157858] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[ 0.159660] tps65910 1-002d: JTAGREVNUM 0x0
[ 0.162048] print_constraints: VRTC:
[ 0.163492] print_constraints: VIO: at 1500 mV
[ 0.165793] print_constraints: VDD1: 600 <--> 1500 mV at 1262 mV normal
[ 0.168094] print_constraints: VDD2: 600 <--> 1500 mV at 1137 mV normal
[ 0.169117] print_constraints: VDD3: 5000 mV
[ 0.170517] print_constraints: VDIG1: at 1800 mV
[ 0.171932] print_constraints: VDIG2: at 1800 mV
[ 0.173346] print_constraints: VPLL: at 1800 mV
[ 0.174760] print_constraints: VDAC: at 1800 mV
[ 0.176191] print_constraints: VAUX1: at 1800 mV
[ 0.177598] print_constraints: VAUX2: at 3300 mV
[ 0.179024] print_constraints: VAUX33: at 3300 mV
[ 0.180441] print_constraints: VMMC: at 3300 mV
[ 0.180937] tps65910 1-002d: No interrupt support, no core IRQ
[ 0.182569] cfg80211: Calling CRDA to update world regulatory domain
[ 0.183214] Switching to clocksource gp timer
[ 0.204195] NET: Registered protocol family 2
[ 0.204406] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.204705] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.204795] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.204851] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.204864] TCP reno registered
[ 0.204877] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.204901] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.205077] NET: Registered protocol family 1
[ 0.205362] RPC: Registered named UNIX socket transport module.
[ 0.205376] RPC: Registered udp transport module.
[ 0.205386] RPC: Registered tcp transport module.
[ 0.205396] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.206136] cpuidle-am33xx cpuidle-am33xx.0: failed to register driver
[ 0.213469] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.213809] msgmni has been set to 241
[ 0.214473] io scheduler noop registered
[ 0.214488] io scheduler deadline registered
[ 0.214570] io scheduler cfq registered (default)
[ 0.215716] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 0.767017] console [ttyO0] enabled
[ 0.771158] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 0.778949] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 0.786706] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 0.794442] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 0.802129] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 0.819361] brd: module loaded
[ 0.827648] loop: module loaded
[ 0.831012] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 0.893256] No daughter card found
[ 0.896847] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 0.904115] am335x_evm_setup()++
[ 0.963256] AM335X: EVM Config read fail: -110
[ 0.967884] No board detected, using GPBoard 1.1A as default
[ 0.973931] The board is general purpose EVM in profile 0
[ 0.979555] Found invalid GP EVM revision, falling back to Rev1.1A
[ 0.986008] -------siglent_fpga_init++
[ 0.990013] -------siglent_fpga_init--
[ 0.994721] da8xx_lcdc.0: alias fck already exists
[ 1.000246] evm_nand_init()++
[ 1.003981] omap-gpmc omap-gpmc: GPMC revision 6.0
[ 1.008984] Registering NAND on CS0
[ 1.013219] evm_nand_init()--
[ 1.017759] haptics_init()++
[ 1.021729] haptics_init()--
[ 1.024777] out_triger_gpio_init()++
[ 1.028540] out_triger_gpio_init()--
[ 1.032735] am335x_evm_setup()--
[ 1.037646] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.044787] omap2-nand driver initializing
[ 1.049377] ONFI flash detected
[ 1.052781] ONFI param page 0 valid
[ 1.056454] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP)
[ 1.065146] Creating 12 MTD partitions on "omap2-nand.0":
[ 1.070789] 0x000000000000-0x000000020000 : "SPL"
[ 1.077156] 0x000000020000-0x000000040000 : "SPL.backup1"
[ 1.084097] 0x000000040000-0x000000060000 : "SPL.backup2"
[ 1.091000] 0x000000060000-0x000000080000 : "SPL.backup3"
[ 1.097951] 0x000000080000-0x000000260000 : "U-Boot"
[ 1.105182] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 1.111985] 0x000000280000-0x000000580000 : "Manufacturedata"
[ 1.120528] 0x000000580000-0x000003080000 : "rootfs"
[ 1.144868] 0x000003080000-0x000003680000 : "kerneldata"
[ 1.154113] 0x000003680000-0x000006880000 : "firmdata0"
[ 1.181550] 0x000006880000-0x000009a80000 : "firmdata1"
[ 1.208981] 0x000009a80000-0x000010000000 : "datafs"
[ 1.257708] OneNAND driver initializing
[ 1.262405] UBI: attaching mtd7 to ubi0
[ 1.266461] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 1.272992] UBI: logical eraseblock size: 126976 bytes
[ 1.278626] UBI: smallest flash I/O unit: 2048
[ 1.283535] UBI: sub-page size: 512
[ 1.288344] UBI: VID header offset: 2048 (aligned 2048)
[ 1.294610] UBI: data offset: 4096
[ 1.709969] UBI: max. sequence number: 577
[ 1.728487] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 9, need 12
[ 1.740175] UBI: attached mtd7 to ubi0
[ 1.744120] UBI: MTD device name: "rootfs"
[ 1.749382] UBI: MTD device size: 43 MiB
[ 1.754473] UBI: number of good PEBs: 344
[ 1.759281] UBI: number of bad PEBs: 0
[ 1.763917] UBI: number of corrupted PEBs: 0
[ 1.768544] UBI: max. allowed volumes: 128
[ 1.773360] UBI: wear-leveling threshold: 4096
[ 1.778258] UBI: number of internal volumes: 1
[ 1.782884] UBI: number of user volumes: 1
[ 1.787519] UBI: available PEBs: 0
[ 1.792146] UBI: total number of reserved PEBs: 344
[ 1.797235] UBI: number of PEBs reserved for bad PEB handling: 9
[ 1.803501] UBI: max/mean erase counter: 7/2
[ 1.807947] UBI: image sequence number: 1632968070
[ 1.813096] UBI: background thread "ubi_bgt0d" started, PID 485
[ 1.863298] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[ 1.869748] davinci_mdio davinci_mdio.0: detected phy mask bfffffff
[ 1.876541] bus->id = 0, addr= 30
[ 1.880188] 11--
[ 1.882314] davinci_mdio.0: probed
[ 1.885899] davinci_mdio davinci_mdio.0: phy[30]: device 0:1e, driver unknown
[ 1.893714] usbcore: registered new interface driver rt2800usb
[ 1.899795] Initializing USB Mass Storage driver...
[ 1.905092] usbcore: registered new interface driver usb-storage
[ 1.911352] USB Mass Storage support registered.
[ 1.916635] mousedev: PS/2 mouse device common for all mice
[ 1.922444] i2c /dev entries driver
[ 1.927234] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.934268] TCP cubic registered
[ 1.937636] NET: Registered protocol family 17
[ 1.942400] NET: Registered protocol family 33
[ 1.947082] lib80211: common routines for IEEE802.11 drivers
[ 1.953025] Registering the dns_resolver key type
[ 1.958005] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 1.966010] ThumbEE CPU extension supported.
[ 1.970519] mux: Failed to setup hwmod io irq -22
[ 1.976038] Power Management for AM33XX family
[ 1.980727] clock: disabling unused clocks to save power
[ 1.987955] Detected MACID=68:9e:19:5c:3a:88
[ 2.067101] UBIFS: recovery needed
[ 2.270801] UBIFS: recovery deferred
[ 2.274562] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 2.280819] UBIFS: mounted read-only
[ 2.284555] UBIFS: file system size: 40632320 bytes (39680 KiB, 38 MiB, 320 LEBs)
[ 2.292537] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 2.300163] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 2.306248] UBIFS: default compressor: lzo
[ 2.310514] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.318288] VFS: Mounted root (ubifs filesystem) readonly on device 0:12.
[ 2.325784] Freeing init memory: 264K
init started: BusyBox v1.13.2 (2012-04-08 17:28:57 CDT)
starting pid 520, tty '': '/etc/init.d/rcS'
rS in
/etc/init.d/rcS: line 14: setterm: not found
Current direction is :"/usr/bin/siglent"
starting pid 534, tty '/dev/ttyO0': '-/bin/sh'
Processing /etc/profile... Done
/ # [1B][34m[INFO]:[1B][0mcalibrate_t():line=81:calibrate_t::calibrate_t()
check_and_upgrade:starting...
mount_fs: rw,ubi1_0,/usr/bin/siglent/usr
ubi1_0unattached
attach_ubi:datafs
attach_ubi:11
[ 5.069235] UBI: attaching mtd11 to ubi1
[ 5.073406] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 5.079936] UBI: logical eraseblock size: 126976 bytes
[ 5.085571] UBI: smallest flash I/O unit: 2048
[ 5.090470] UBI: sub-page size: 512
[ 5.095289] UBI: VID header offset: 2048 (aligned 2048)
[ 5.101545] UBI: data offset: 4096
[ 6.074508] UBI: max. sequence number: 31102
[ 6.103391] UBI: attached mtd11 to ubi1
[ 6.107407] UBI: MTD device name: "datafs"
[ 6.112669] UBI: MTD device size: 101 MiB
[ 6.117858] UBI: number of good PEBs: 812
[ 6.122666] UBI: number of bad PEBs: 0
[ 6.127303] UBI: number of corrupted PEBs: 0
[ 6.131930] UBI: max. allowed volumes: 128
[ 6.136747] UBI: wear-leveling threshold: 4096
[ 6.141645] UBI: number of internal volumes: 1
[ 6.146281] UBI: number of user volumes: 1
[ 6.150907] UBI: available PEBs: 0
[ 6.155544] UBI: total number of reserved PEBs: 812
[ 6.160623] UBI: number of PEBs reserved for bad PEB handling: 32
[ 6.166980] UBI: max/mean erase counter: 58/38
[ 6.171608] UBI: image sequence number: 79843063
[ 6.176537] UBI: background thread "ubi_bgt1d" started, PID 554
UBI device number 1, total 812 LEBs (103104512 bytes, 98.3 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
MOUNT_DIR_NAME = /usr/bin/siglent/usr
TEST_RESTURN =
is_fs_mounted 0 ---
[ 6.289626] UBIFS: recovery needed
[ 6.445662] UBIFS: recovery completed
[ 6.449504] UBIFS: mounted UBI device 1, volume 0, name "rootfs"
[ 6.455785] UBIFS: file system size: 97136640 bytes (94860 KiB, 92 MiB, 765 LEBs)
[ 6.463778] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 6.471395] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 6.477480] UBIFS: default compressor: lzo
[ 6.481746] UBIFS: reserved for root: 0 bytes (0 KiB)
is_need_upgrade
is_need_upgrade:not need upgrade
check_and_upgrade:end...
++mount_check_copy_appdata: starting
mount_fs: ro,ubi2_0,/usr/bin/siglent/firmdata0
ubi2_0unattached
attach_ubi:firmdata0
attach_ubi:9
[ 6.551622] UBI: attaching mtd9 to ubi2
[ 6.555718] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 6.562249] UBI: logical eraseblock size: 126976 bytes
[ 6.567885] UBI: smallest flash I/O unit: 2048
[ 6.572784] UBI: sub-page size: 512
[ 6.577603] UBI: VID header offset: 2048 (aligned 2048)
[ 6.583869] UBI: data offset: 4096
[ 7.065982] UBI: max. sequence number: 34
[ 7.093376] UBI: attached mtd9 to ubi2
[ 7.097301] UBI: MTD device name: "firmdata0"
[ 7.102834] UBI: MTD device size: 50 MiB
[ 7.107936] UBI: number of good PEBs: 400
[ 7.112743] UBI: number of bad PEBs: 0
[ 7.117392] UBI: number of corrupted PEBs: 0
[ 7.122019] UBI: max. allowed volumes: 128
[ 7.126837] UBI: wear-leveling threshold: 4096
[ 7.131735] UBI: number of internal volumes: 1
[ 7.136371] UBI: number of user volumes: 1
[ 7.140997] UBI: available PEBs: 0
[ 7.145633] UBI: total number of reserved PEBs: 400
[ 7.150713] UBI: number of PEBs reserved for bad PEB handling: 16
[ 7.157069] UBI: max/mean erase counter: 2/1
[ 7.161515] UBI: image sequence number: 1976655378
[ 7.166626] UBI: background thread "ubi_bgt2d" started, PID 579
UBI device number 2, total 400 LEBs (50790400 bytes, 48.4 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
MOUNT_DIR_NAME = /usr/bin/siglent/firmdata0
TEST_RESTURN =
is_fs_mounted 0 ---
[ 7.359768] UBIFS: mounted UBI device 2, volume 0, name "firmdata0"
[ 7.366338] UBIFS: mounted read-only
[ 7.370065] UBIFS: file system size: 46854144 bytes (45756 KiB, 44 MiB, 369 LEBs)
[ 7.378059] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 7.385687] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 7.391763] UBIFS: default compressor: lzo
[ 7.396038] UBIFS: reserved for root: 0 bytes (0 KiB)
--mount_check_copy_appdata: ending
$Task start:: SCPI
example_thread++
[ 7.683648]
[ 7.683659] CPSW phy found : id is : 0x20005c90
[ 7.690666] PHY 0:01 not found
[ 7.762294] gpib_usb_init
$Task start:: Devce
vxi11_main = 7890.12
$Task start:: Udisk&Lan
drv_instance_manage_t: produce_id: 10600
(DRV_PRODUCT_SDG2000)
_drv_product=0
[ 8.963270] sched: RT throttling activated
[ 9.023988] usbcore: registered new interface driver usb-gpib
init_spi:: name = /dev/spidev1.0
init_spi:: handle = 17
_init_load_fpga_file_to_fpga()::str_path = /usr/bin/siglent/config/fpga/fpga.bin
[1B][34m[INFO]:[1B][0mload_cali_data():line=1544:sdg2000 load from usr cali data OK
Config module error:lib_xml_t::set_content = iq:max_amp:
Config module error:lib_xml_t::set_content = iq:min_amp:
Config module error:lib_xml_t::set_content = iq:max_sample_rate:
Config module error:lib_xml_t::set_content = iq:min_symbol_rate:
Config module error:lib_xml_t::set_content = iq:max_center_frq:
Config module error:lib_xml_t::set_content = iq:min_center_frq:
Config module error:lib_xml_t::set_content = iq:max_gain_balance:
Config module error:lib_xml_t::set_content = iq:min_gain_balance:
Config module error:lib_xml_t::set_content = iq:max_Q_Angle:
Config module error:lib_xml_t::set_content = iq:min_Q_Angle:
Config module error:lib_xml_t::set_content = iq:max_offset:
Config module error:lib_xml_t::set_content = iq:min_offset:
I/O error : Read-only file system
Config module error:lib_xml_t::set_content = device:Support_IQ_Flag:
mod_if_exit_handler:signal=11
Clean Up Ready!
Clean Up - Example
Clean Up - SCPI
Clean Up - dev_thread
Clean Up - dev_interpreter_main
Clean Up - USBTMC
Clean Up - ui_task
Clean Up - touch_task
Clean Up - key
Clean Up - Config
Clean Up - Config assistant
Clean Up - Config_assistant_voltage_overload
Clean Up - VXI_11
Clean Up - telnet_scpi
Clean Up - socket
Clean Up - GPIB
Clean Up - Timer
Clean Up Over!
I measured all hardware voltages, they are all as expected and the FPGA and Linux Heartbeat LEDs are blinking like they should.
I tried starting the sdg2000.app manually per nonsole but this ends in the same error, some configuration seems to be bricked.
I would like to try reflashing the firmware but I don't know how to do this via UART.
I would be really happy if I can restore this unit!
