Author Topic: The Siglent SDG2042X Thread  (Read 646180 times)
Offline DL2XY
Re: The Siglent SDG2042X Thread
« Reply #1325 on: March 29, 2021, 07:46:35 am »
Perhaps you could show it with a more faster modulation? 1 Hz is quite slow you know and superimposed on a square wave is hard for me to visualise on a scope.
The spectrum clearly shows 1kHz modulation so i think 1Hz is a typo.
Have run this on a SDG 6052 for about an hour - no probs.
Offline hpw
« Reply #1326 on: March 29, 2021, 07:59:09 am »
just read as posted:
- FM 1kHz = modulation
- Freq. Dev 1Hz
and than wait about 1 minute, sometimes the mod button has to be pressed twice, so the modulation starts again
« Last Edit: March 29, 2021, 08:00:41 am by hpw »
Offline Blue
  • Fighting for peace is like fucking for virginity
« Reply #1327 on: March 29, 2021, 07:54:06 pm »
As I have changed the fan to a quiter version, I wanted to analyse the temperature of the components using my flir camera.
Quite shocking is the extreme heat produced by some resistors.
For example in the power supply:
Offline Blue
« Reply #1328 on: March 29, 2021, 07:56:51 pm »
The DAC area
Offline Blue
« Reply #1329 on: March 29, 2021, 07:57:55 pm »
another very small resistor:
* 20210329_204840_0.jpg (83.06 kB. 384x288 - viewed 168 times.)
Offline Blue
« Reply #1330 on: March 29, 2021, 08:01:27 pm »
Offline Blue
« Reply #1331 on: March 29, 2021, 08:04:19 pm »
some more
Offline Blue
« Reply #1332 on: March 29, 2021, 08:17:32 pm »
The main problems are in the powersupply:
D18 (Shottkey?) diode @ 102 °C
Three 2002 Resistors R29,  R25, R44 @ 170 °C
I have an input of 230.4 V AC right now!
« Last Edit: March 29, 2021, 08:44:33 pm by Blue »
Offline Blue
« Reply #1333 on: March 29, 2021, 08:24:59 pm »
Offline Blue
« Reply #1334 on: March 29, 2021, 08:28:23 pm »
What do you think of these findings?
Is there anyone who had a failing powersupply?
« Last Edit: March 29, 2021, 08:41:05 pm by Blue »
Offline TurboTom
« Reply #1335 on: March 29, 2021, 08:32:22 pm »
The SDG6000X has got its own share of problems under these condintions as well. See here.
@Blue: The temps are okay except for the 160C resistor... That's smoking hot, it will tan the PCB in no time, make the copper clad adhesive brittle and even foul the solder eventually. I guess these are the startup resistors of the PSU that get that hot. If your in the Netherlands as shown in your avatar (?) -- high five to our neighbours  ;) --, your SDG will run on 230VAC, causing these dropper resistors to dissipate a considerable amount (four times as much) of power in comparison to countries that run a 115VAC mains (but that's less than half as much fun "to the touch"  8)). I may check temps in my SDG6000X that's probably equipped with the same PSU, and maybe replace the resistors with such of twice the resistance. My SDG will probably never run off 115V...
« Last Edit: March 29, 2021, 08:47:06 pm by TurboTom »
« Reply #1336 on: March 29, 2021, 09:09:08 pm »
Not here in NZ or anywhere else that I can recall.
Offline Blue
« Reply #1337 on: March 29, 2021, 09:14:28 pm »
Do you think that these resistors were designed for a powersupply running at 110V?
Would replacing these 20K Ohm to e.g. 40 Kohm still work?
I bought them at Batronix, will they complain about me opening the SDG?
What shall I do?
Offline TurboTom
« Reply #1338 on: March 29, 2021, 09:22:43 pm »
Use it as it is. The resistors will run at this temerature, no problem, but the PCB will suffer. Nevertheless, I haven't heard of any of these suppies fail. So probably, just "don't worry, be happy" and deal with the problems if they should arise. Still, IMO, it's not a good design practice by the manufacturer to allow components to run that hot in some parts of the woods...
The following users thanked this post: Qw3rtzuiop
Offline Blue
« Reply #1339 on: March 29, 2021, 11:10:35 pm »
Apparantly my powersupply in the SDG is different than show in Dave's teardown
They have changed things and botched up
« Reply #1340 on: March 29, 2021, 11:32:26 pm »
The complete lack of PSU warranty claims suggests otherwise.
Offline Roger Need
« Reply #1341 on: March 30, 2021, 05:15:49 pm »
As I have changed the fan to a quieter version,
Blue,
What fan make/model # did you use for the replacement?  Did it reduce the noise level much?
Roger
Offline exe
  • self-educated hobbyist
« Reply #1342 on: March 30, 2021, 05:18:31 pm »
From the picture it's not obvious to me if it's a peak temperature on the image, or it's just a range indicator. I'd expect central marker to show the peak temperature.
So... what model of thermal camera is that?
Offline Blue
« Reply #1343 on: March 30, 2021, 05:32:42 pm »
In the left upper corner you weill see two numbers with an arrow (solid triangle). They correspond to the temperatures of the triangles in the picture.
They are also min and max of the whole picture when the temperature range is not locked (see left lower corner while using the instrument - is not recorded in these pictures).
In addition, there is a centre cross with it's own temperature.
I'm using a Therm-App made by Ogal.
Online blurpy
  • Country: no
« Reply #1344 on: March 30, 2021, 05:42:38 pm »
Wondering that as well, looking into one and the pictures looked pretty good.
Offline exe
« Reply #1345 on: March 30, 2021, 07:03:05 pm »
Ah, missed triangles on the picture. Oh shi~, that's bad. The temperature here is during the spring, and with open enclosure. I can imagine during the summer it'll be significantly hotter.
Offline Blue
« Reply #1346 on: March 30, 2021, 08:25:02 pm »
I checked the readings from the flir with a ultra small thermocouple made from GG-KI-36-SLE and an AD595 / 9V battery
It is a bit difficult to get a 0.3 mm thermocouple attached but I managed.
The readings from the thermocouple attached to the resistor with Kapton tape was around 120C. Was not perfectly connected. Still way too high.
Few uncertainties remain. Emissivity used in the flir was 0.95. Are the components being measured correctly?
Thermocouple was not calibrated above 100C.
Anyway, I remain confident that the resistors and diode are being overstressed.
And for those who think it is ok, it would be nice if you power your Siglent on for at least 3 months, 24/7. And then report back here what happened. Would be nice if you could take pictures.
Does anyone dare?
« Last Edit: March 30, 2021, 08:53:01 pm by Blue »
Offline JohnG
« Reply #1347 on: March 31, 2021, 01:34:36 am »
I would consider the following possibility:
If you are doing thermal images, that implies the cover is off. This is likely to affect the airflow substantially, and often makes the cooling worse because the air can take the easy path out the open box, rather than the harder path along the circuit board and components.
When you use the thermocouple, you can put the cover on and see if it makes any difference.
Cheers,
John
"Reality is that which, when you quit believing in it, doesn't go away." Philip K. Dick (RIP).
The following users thanked this post: rf-loop
Offline Blue
« Reply #1348 on: March 31, 2021, 06:37:20 am »
Hi JohnG,
No difference measured with or without plastic cover (Its not possible to slide the metal cover back without slicing the thermocouple)
Hardly any airflow over the components due to their location and shielding.
« Reply #1349 on: March 31, 2021, 06:44:16 am »
Hi JohnG,
Yes well if you have changed the fan and run it on low speed as you reported here:
https://www.eevblog.com/forum/testgear/the-siglent-sdg2042x-thread/msg3535016/#msg3535016
I'm sorry Blue but we can't take your reports seriously when you're not running the OEM fan.
