If one work with audio 600ohm impedance system SDG2000X have solution.
Do not use default 50ohm Load setup, adjust it to 600ohm.
Now if you set 0dBm level is 0dBu and you see 0.7746Vrms (1.095V pk) and if you set level for -10dBu your level is 0.2448Vrms (0.346Vpk or double Vp-p)
Thanks for reminding me of this which I should have known. While making the measurements using the SDG 2042X by brain was occupied with troubleshooting the difficult target. This well-broken R&S UPGR Psophometer. But all is well now.
When setting the SDG to 600 Ohms and 0.0 dB amplitude is off by +0.7 dB. Faking the load to 495 Ohms gives the correct output of 0.7746 V as measured with the equipment given below.
Being off by +0.7 dB seems to me a bit much. Could any other SDG 2042X (or similar) owners verify this?
Bit high: Error is 0.7dB too high.
Data sheet tell +/- 0.3dB flatness with 50 Ohm system in 0 - 100MHz range and 2.5Vpp level @10kHz
Accuracy +/- (1% +1mV) @10kHz Sine 0V offset
Internal output impedance 49.5 - 50.5 Ohm @10kHz Sine
Then output set for 0dB
m (not 0dB) for 600ohm what need give 0.7746Vrms but voltage is too high and you change load to 495ohm and then voltage level is 0,7746Vrms.
When I try to calculate it looks like something is weird or least I can not get match this Load change... except if there is bug in SDG math or some kind of calibration issue or some other thing is wrong.
Using 0dBm on 600Ohm system level is 0.7746 Vrms
If it is 0.7dB high it is 0.8395 Vrms there is roughly 65mVrms difference. What all separate errors it include.
Next measurements may give more result and also there is used frequency what are used in specifications.
So please can you do these measurements.Set generator first fully to factory defaults for avoid any "oops" mistakes..
1.
-Set
Load Hi-Z and keep it until said other set value
-Set Sine and set
10 kHz. Set output level 0.775 Vrms and keep until sais other value.
-Set/check DC offset 0 and check it do not have any residue, if have fine adjust for real Zero DC offset and keep this in all next.
-Measure
open circuit voltage level Vrms (AC True Rms or AC+DC True Rms) Result =______ (default = 0.775 Vrms)
-Connect 600 ohm load and measure
loaded voltage level Vrms, Result =______ (default = 0.7154 Vrms)
-Connect 100 ohm load and measure
loaded voltage level Vrms, Result =______ (default = 0.5167 Vrms)
2.
-Set
Load 50 Ohm and keep it
-Output level set for 0.775 Vrms
-Measure
Open circuit voltage level Vrms, Result =______ (default 1.550 Vrms)
-Connect 50 Ohm Load and measure
loaded voltage level Vrms, Result =______ (default 0.775 Vrms)
-Set output level for 0dBm and measure
loaded voltage level Vrms, Result =______ (default 0.2236 Vrms)
-Set output level for 6dBm and measure
loaded voltage level Vrms, Result =______ (default 0.4462 Vrms)
-Set output level back for 0dBm
-Disconnect 50 ohm load and measure
open circuit voltage level Vrms, Result =______ (default 0.4472 Vrms)
3.
-Set
Load 600 Ohm and keep it
-Set Output level for 0.775 Vrms
-Measure
open circuit voltage level Vrms, Result =______ (default 0.8396 Vrms)
-Connect 600 Ohm Load and measure
loaded voltage level Vrms, Result =______ (default 0.775 Vrms (ideal 0.7746 Vrms))
loaded voltage level Vrms, Result =______ (default 1.546 Vrms)
-Disconnect 600 Ohm load and measure
open circuit voltage level Vrms, Result =______ (default 1.675 Vrms)
Sorry if there is some inaccuracies (I hope not real mistakes) in values, I use slide rule.
