I am trying to automate the modulation of a sinusoidal carrier with a custom waveform. According to the programming manual, this is possible.
This command sets up a modulated DSB-AM carrier with an arbitrary (ARB) modulating wave shape (MDSP)
C1:MDWV DSBAM,MDSP,ARB
However, nowhere in the programming manual does it explain how to set the arbitrary waveform used for modulation.
The obvious command only sets the arbitrary waveform for the carrier, and has no impact on the modulating waveform.
C1:ARWV NAME,custom
And the specific modulating waveform being used is not reported when querying the state of the channel.
C1:MDWV?
C1:MDWV STATE,ON,DSBAM,MDSP,ARB,SRC,INT,FRQ,0.1610824742HZ,CARR,WVTP,SINE,FRQ,28121000HZ,AMP,0.1V,AMPVRMS,0.03535Vrms,AMPDBM,-16.0219dBm,OFST,0V,PHSE,0
Does anyone know how one would, via SCPI, set the waveform used for modulating a carrier on the SDG2000X?
Is there a "complete" list of commands used by Siglent's AWG (including the undocumented ones) floating around? I have found the one for their 'scopes to be a necessity when doing any sort of automation.
