I've just received one (dirt cheap even though I had to pay 35 euros in Spain due to customs processing and 21% VAT) and at least trying with the lab power supply, a multimeter and the oscilloscope I get useful intensity readings on the oscilloscope my extremely über high end, NASA-budget-no-less Rigol DS1074Z.
I got the probe mostly out of curiosity after reading the review mentioned, and I am sure it can be useful even though I will mostly use a µCurrent for my microntroller measurements. But, for the price, the thing is amazingly accurate.
Some data points. The PS is an AIM-TTI EL302R, a Fluke 87V using the amps socket (not the mA/µA as I am surpassing 400 mA) and the Rigol DS1074Z "Enhanced Editlol".
The current probe has three ranges:
- 400 mA (1 mV/mA, max 0.5 A)
- 4 A (100 mV/A, max 5 A)
- 40 A (10 mV/A, max 50 A)
The thing is noisy. With 200 ms/div horizontal, 5 mV/div vertical, and the power supply set to 4 mA (4.7 mA according to the 87V), the oscilloscope is measuring an average of 4.3 mA, but with a peak to peak noise of 18 mA, that with the 20 MHz filter engaged. That's for normal capture mode. In high res, noise is around 9 - 10 mV peak to peak, but the reading is worse, averaging 4.3 mA more or less.
Setting a more realistic scale on the oscilloscope, 50 mV/div, the noise is not that apparent (still in high resolution mode) and, for example, 4.5 mA on the 87V translate to 4 mA on the oscilloscope. Raising the power supply to 10.0 mA (87V) the oscilloscope is measuring an average of 9.9 mA, not bad! (I am hitting clear each time I change the intensity setting on the power supply, and waiting for several seconds).
At 100 mA (87V fluctuating between 99.9 and 100.1 mA, which is the precision limit of the multimeter anyway) the oscilloscope is measuring between 99.5 mA and 100 mA.
So it seems it can measure some mA with a reasonable accuracy. I am interested on doing some tests with an ESP8266, timing some sensor readings and WiFi transmissions together with their timings, and this seems to be suitable. Actually I will be using a µCurrent as well, which will be especially useful to measure sleep times.
I haven't tried with AC, and I haven't tried the 40 A range. I will probably try this weekend when I use the HF transceiver.
